Erased FPGA Flash sector
- Cyber
03 Jul 2023 14:02 #274691
by Cyber
Erased FPGA Flash sector was created by Cyber
I have erased an FPGA sector 0x00010000, and the connection has been lost between the PathPilot controller and the Torstep board. Sounds like the IP address was erased from the memory device. I have restored the PathPilot to factory default and still have the same problem. any solution?
how can I connect back to the board?
- Thank you received: 7491
03 Jul 2023 22:45 #274716
Replied by tommylight on topic Erased FPGA Flash sector
What FPGA?
What is TorStep?
Moved to "driver boards" for now, or should it be at "Path Pilot" section?
What is TorStep?
- Cyber
03 Jul 2023 23:17 #274718
by Cyber
Replied by Cyber on topic Erased FPGA Flash sector
Torstep is a card developed by Tormach for their machine, it uses Hostmot2 much like the mesa's card. I have used the commands to erase the FPGA FLASH EEPROM CHIP ACCESS sector from 7I92 ETHERNET
ANYTHING I/O MANUAL.
03 Jul 2023 23:34 #274720
I refrained from asking the first time, but why would you erase that?
- Cyber
04 Jul 2023 00:13 #274721
by Cyber
I'm new to linuxcnc and was performing read-and-write commands to see how the machine would act
- tivoi
- Thank you received: 20
05 Jul 2023 07:43 #274814
by tivoi
Replied by tivoi on topic Erased FPGA Flash sector
try this video
The following user(s) said Thank You: Cyber
