Strange behaviour of Linuxcnc 2.8.4 with 7i96s latest FW
  • curryman
  • curryman's Avatar Topic Author
  • New Member
  • New Member
17 Jul 2023 19:42 #275671 by curryman
After problems with a pluto board I changed to a MESA 7i96s board. Configuration and handling was quite straight, and no real issue popped up during installation and configuration. Only the Ethernet Card I have used for communication uses a real tech chipset, what leads to real time issues.
But the change to the native real tech driver solved the problem. Anyhow, to understand the configuration and its parameters, I observed the pins STEP and DIR with a logic analyzer.
I started with the following configuration and what I expected is added:
DIRSETUP = 2000 => I understand the DIR signal becomes active at least 2µs before the first step pulse.
DIRHOLD = 2000  => The DIR Signal stays at leased 2µs after the last step pulse.
STEPLEN = 200   => The pulse length is fix 200ns
STEPSPACE = 200 => The pulse pause related to acceleration and speed flexible but at least minimum 200ns
So measurement of the DIRSETUP is for both direction as expected. I see after 20µs after the rising edge of the direction signal the first step pulse. In the other direction I see of course nothing.
Interesting is the end of the direction signal.
In the first example with the active direction signal the end is really strange. I forced that direction ~1,5s. After that time the signal becomes low for the first time, but 128µs before the last step pulse. Than it stays for 2ms low and turns than to high again for 3ms. Than low for 2ms and final high for 2ms.
The first what I was thinking, it is some kind of bouncing. But it is not I repeated the measurement many times and the timing is always exactly the same. Bouncing is much more random.
BTW. the measured step pulse length is exact 200ns
[img]data:image/png;base64,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[/img]
[img]data:image/png;base64,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[/img]
But that means the last step pulse is going in the wrong direction.
The other direction is more or less the same.
Overview:
[img]data:image/png;base64,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[/img]
Detail:
[img]data:image/png;base64,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[/img]
Has someone an explanation for that behavior, or is that a failure?
I did the measurement with Logic2 from Saleae.
File Name: LinuxCNC_Mesa_02.zip
File Size:44 KB
File Size:44 KB
  • curryman
  • curryman's Avatar Topic Author
  • New Member
  • New Member
17 Jul 2023 19:45 #275672 by curryman
I do not understand why the pictures are not visible. During editing they were perfect visible.
17 Jul 2023 19:57 #275676 by PCW
Because the step generator is in a PID feedback loop, depending on tuning, and precise floating point position
there may be single step reversals at stops but in no case are actual step count or timing violations present.
this is guaranteed by the hardware.
Moderators: PCW, jmelson
Time to create page: 0.200 seconds
