ISO 7i97
03 Aug 2023 00:02 #276803 by FortheShiz
ISO 7i97 was created by FortheShiz
Does anyone know a source to get a mesa 7i97 analog servo board. I have been waiting patiently since there is supposed to be a new version released but I am now needing my machine to be running instead of just wanting so I am looking to purchase one sooner rather than later.
04 Aug 2023 14:56 #276890 by fons
Replied by fons on topic ISO 7i97
i'm also looking for a 7i97 and i can offer a 7i76E something like an exange
me planes change i will keep the dc motor from the late instead of replace them to modern 3f servo motor
  • Moderator
  • Moderator
04 Aug 2023 15:16 #276891 by tommylight
Replied by tommylight on topic ISO 7i97
7i96S+(7i85 or 7i85S)+7i83
That makes something near 7i97, just check number of analog/encoder/etc.
And can be found readily, mostly.
27 Sep 2023 19:27 - 27 Sep 2023 19:31 #281735 by fons
for  me lathe i need  48 Di and 24 Do
when i use  a 7i76e whitch i have and i add
the 7i85s encoder input for  X and Z axes and 2 encoder inputs for the 2 tool turntable       4 encoder inputs i need all of them
the  7i83  analog out  for the 4 drivers  X , Z , T1 and T2                                                        6 analoog out      i need  4 of them
the  7i84  for aditional Di and  Do
the 7i76e had 32 Di  and  16 Do   same as 7i84  make a total  of 64 Di and  32 Do               i need  48 of 64 Di and 24 of 32 Do
can i conect this  3 cards (7i85s ,7i83 and 7i84 ) to the 7i76e and wil linux cnc 2.8.4   all in and outputs recognice  automaticly
do i have to order some special cable  to let it work  ?
this 3 cards are in stock at eusurplus  for 337€
Last edit: 27 Sep 2023 19:31 by fons.
  • Moderator
  • Moderator
28 Sep 2023 01:09 #281753 by tommylight
7i76E to 7i85S you need a short IDC26 pin to DB25 pic cable, eusurplus has those and are cheap ( or 7i85 with no S, in your case may be better as you can add more SSerial boards)
7i76E to 7i83 through a network cable, CAT5 or CAT6 or CAT5E
7i85S (or 7i85) to 7i84 through a network cable, CAT5 or CAT6 or CAT5E
7i76E will probably need to be flashed with new firmware, might be already included on the Mesa website with the downloads for it.
7i83 and 7i84 do not need any flashing, they just work, but will need to be added in hal, most probably PncConf will get you very close to whatever you would need.
17 Nov 2023 10:20 - 18 Nov 2023 18:27 #285721 by fons
eusurplus sugested me to use a 7i80hdt in combination with a 7i48 to control a 6axis analog system  this board are available
can linux cnc handle these combination right out of the box  ?  a need for  firmwear update ?
on the 7i80 are 72 I/O available  devided on the 3 pinheaders  1 header will be used for the connection to the  7i48
are the  72 I/O stil available on the  2 leftover  or only 48 ?
do i need for  the I/O an addition cart 7i84 who had  32 I and 16 O can it be connet as one  ?
Last edit: 18 Nov 2023 18:27 by fons.
Moderators: PCW, jmelson
Time to create page: 0.200 seconds
