Board selection for analog servo drives
  • Trav328
  • Trav328's Avatar Topic Author
  • Senior Member
  • Senior Member
11 Aug 2023 02:25 #277588 by Trav328
Hi , I just picked up a 1996 standard modern lathe with a bad centurion controller , the lathe uses parker MPA analog drives and servos.
A  bit in the selection of boards , I require analog control +/- 10v for the mpa drives for axis and spindle , the drives require a sinking control to enable/reset but the rest of the machine runs on a 24v system for all limits
the drives have resolvers but output a simulated encoder signal for linuxcnc , the spindle (also a mpa drive) has a heidenhan encoder as well as a resolver.
I will also need to control a pragati tool changer that has a small 3 phase motor with a absolute encoder (i havent tore into this much yet)
thankful for any help in selection you guys/gals can offer , happy to be back on a forum its been a few years.
I also understand that boards are in short supply , I don't have a problem waiting a couple months for the right combo.
Attached is a picture of the drive wiring diagram
  • Trav328
  • Senior Member
  • Senior Member
11 Aug 2023 02:33 #277589 by Trav328
Replied by Trav328 on topic Board selection for analog servo drives
11 Aug 2023 03:42 #277592 by PCW
Replied by PCW on topic Board selection for analog servo drives
Mesa should have 7I97T cards in 6 weeks (basically the same as a 7I97 but with a different FPGA)
  • Trav328
  • Senior Member
  • Senior Member
11 Aug 2023 04:19 #277596 by Trav328
Thanks for the fast reply , that looks like the ticket , I will keep an eye out for them to come avilable
11 Aug 2023 14:39 #277643 by jmelson
Replied by jmelson on topic Board selection for analog servo drives
One option is the Pico Systems PPMC, a set of boards with encoder counter, D/A converter and digital I/O. I did a retrofit on a similar machine with MTS servos, with resolvers where the drives make a quadrature output. It worked quite well.
(full disclosure, I am Pico Systems.)
See: pico-systems.com/osc2.5/catalog/index.php?cPath=1
for more info.
Jon
  • Trav328
  • Senior Member
  • Senior Member
11 Aug 2023 14:49 #277644 by Trav328
Thanks,  I will look into the pico aswell
13 Aug 2023 15:13 #277835 by msrdiesel
Replied by msrdiesel on topic Board selection for analog servo drives
"I will also need to control a pragati tool changer that has a small 3 phase motor with a absolute encoder (i havent tore into this much yet)"
I have used 3 phase solid state relays for this purpose, you can use a digital output and hold it "HIGH" to perform the rotation until whatever sensor is triggered.
They tend to be well over-rated so buy one bigger than you need if you go this route. I have used these successfully in upgrading a Tos Hostivar OD grinder to touch screen control.
Here is a link to the relay: www.amazon.com/Baomain-Phase-JGX-3340A-4...ay%2Caps%2C92&sr=8-3
13 Aug 2023 15:23 #277836 by COFHAL
Replied by COFHAL on topic Board selection for analog servo drives
What servo motor are you using?
13 Aug 2023 16:05 - 13 Aug 2023 16:07 #277838 by COFHAL
I think it is the only solution to control several analog servos with resolvers
, I am controlling a single Parker analog servo with a 7i33TA and a 7i96 with a special firmare that replaces step 4 with PWM and dir, thanks PCW. Since those MPA servos have a simulated incremental encoder output with a resolution of 1024, I connected it to the encoder input of the 7i96 and with that I have feedback of the servo motor position.
Last edit: 13 Aug 2023 16:07 by COFHAL.
  • Trav328
  • Senior Member
  • Senior Member
14 Aug 2023 22:27 #278007 by Trav328
Thanks for the input , "msrdiesel" i watched the videos of your fadal and that is the inspiration for my front panel , very nice  and clean looking job,
i have used those solid state relays for other projects and they work good , my powder coating oven has 3 of the single phase ones in it.
  im only going to be running single phase to the machine as its all i have and the amps support it , i might look into swapping the tool change motor for something else or use a vfd/dps to run it , its only small.
"cofhal" , i dont know what the servos are they are burried and not pleasant to get to , the drives are 1996 MTS (now parker hannifin) MPA-06 for the axis , and MPA-50 for the spindle , running in single phase mode , the drives seem very user friendly and i have found quite a few manuals online for them , the spindle has 4 winding selections that equal 3 "ranges" for now its just going to stay locked in low but its setup to be controlled by 2 relays. the spindle also has a dedicated heidenhan encoder . i will be using the simulated encoder for the axis.
The following user(s) said Thank You: msrdiesel
Moderators: PCW, jmelson
Time to create page: 0.177 seconds
