[Resolved]Struggling with MESA driving VFD using 0-10v 7i96s->7i76
18 Aug 2023 09:50 - 18 Aug 2023 09:52 #278339 by camb0
I'm having some trouble getting the following to work in 0-10v
-MESA 7i96s -> 7i76 -> TB4 spindle driver connector
-Folinn BD600
Pin connections are below.
If I turn the spindle on, I get the correct scaled voltage on pin 2 ie 2.5V when at 1/4 speed, however the spindle doesn't startup.
If I pull cables S1, S2, GND from the TB4 and connect them manually I get the motor to go forward (S1->GND) and reverse (S1&S2->GND) so it seems like the VFD is setup correctly and basic wiring is in place.  But it's not working from the Linux->MESA control.
What I've tested:
When connected S1 and S2 have ~25v on them to the VFD GND wire.
When turning the spindle on S1 goes to ~0.8v, S2 stays 25v.
When turning the spindle in reverse S1 is at ~0.8v and S2 goes to ~0.8v.  (So MESA transistor(s) seems to be working).
I've tried reversing the signal -> gnd pins, it seemed to work sometimes and the motor starts up intermittently but the motor wouldn't turn off fully, it would drop to a really slow RPM (<10 rpm? ) and there was some Hz getting registered on the VFD, but no voltage on Pin2/A1 relative to ground... (earth leakage/noise potentially? I've used shielded cable and earthed it.)
I've tried using ENA and DIR pins to drive an external SSR with the same results.. maybe I need a mechanical relay?
Something I'm doing preventing me from getting a switch type of connection between S1 and S2 to ground....
Maybe I need a pull-up/pull-down resistor??.. (FYI if it's not obvious I'm not really confident with electronics, ok with electrics)
Maybe I need to run multiple ground wires, currently I'm sharing the one wire to the VFD as my cable was 6 core shielded not 8.
MESA                               DESC                   BD600 connection
MESA PIN 8 = Spindle DIR +         --> Reverse           --> S2
MESA PIN 7 = Spindle DIR -         --> GND               --> DCM/ACM
MESA PIN 6 = Spindle Enable +      --> FWD               --> S1
MESA PIN 5 = Spindle Enable -      --> GND               --> DCM/ACM
MESA PIN 3 = Spindle +             --> 10V               --> 10v
MESA PIN 2 = Spindle OUT           --> Target value      --> AI1 (0-10v)
MESA PIN 1 = Spindle -             --> Gnd               --> ACM/DCM
Note that I tried to get it running via VFMOD and didn't have any success, I was told that the modbus is broken in the latest firmware by Conan motor (in AU), F07.09 = 30.012.  But it could also be the ebay RS485 usb driver.
Last edit: 18 Aug 2023 09:52 by camb0. Reason: formatting
  • Moderator
  • Moderator
18 Aug 2023 10:44 #278342 by tommylight
Try in MDI
M3 S1000
The following user(s) said Thank You: camb0
18 Aug 2023 12:10 - 18 Aug 2023 12:12 #278360 by camb0
Thx Tommy
I had tested the scaling using the m3 s1000 as well as via the UI.
I also had Halshow up watching the spindle pins, velocity/rpm and MESA outputs which all looked to be ok.
 Very open to any other ideas suggestions as well.
Last edit: 18 Aug 2023 12:12 by camb0.
18 Aug 2023 12:48 #278365 by PCW
If the FWD/REV wires switch from ~25V to ~0.8V and the Analog out is about right,
there's nothing wrong with the 7I76, Sounds like wiring, VFD setup or VFD fault.
19 Aug 2023 04:19 - 19 Aug 2023 04:35 #278438 by camb0
I rewired it w/8 shielded cores and still have the same problem.
The voltage drop improved and went to 0.75 (was 0.82 or thereabouts).
I found I needed to increase the VFD signal delay time (was looking for a voltage threshold but didn't find for S1 or S2), F05.12 = 0.010s by default, changing it to 0.030s seems reliable.
Thx for the help.
Last edit: 19 Aug 2023 04:35 by camb0.
Moderators: PCW, jmelson
Time to create page: 0.239 seconds
