Mesa card 7i90 error following
- telmoram
26 Aug 2023 14:39 #279008
by telmoram
Mesa card 7i90 error following was created by telmoram
Hi, can you help me?, I have board 7i90hd with 7i85s in pwm mode, motors calibrated and manual move its ok, run the program then work and randon execution time have error following in all axes, i revised the 7i90hd the w1 jumper it's in down position, w6 up position, this is problem?, and the fpga could damage?.
Thanks.
Thanks.
- Thank you received: 5334
26 Aug 2023 16:26 #279010
Replied by PCW on topic Mesa card 7i90 error following
How is the 7I90HD interfaced to the host computer?
- telmoram
26 Aug 2023 17:23 #279011
by telmoram
Replied by telmoram on topic Mesa card 7i90 error following
Interface host integrated parallel port with epp mode.
26 Aug 2023 17:37 #279012
It sounds like perhaps a ground loop generating noise in the EPP interface
A shorter parallel cable and single point grounding may help as may
common mode chokes (ferrite beads) in any connection to noise sources
(Motor drives etc)
(Motor drives etc)
The following user(s) said Thank You: telmoram
- telmoram
27 Aug 2023 02:40 #279061
by telmoram
ok thanks, i will review the connections.
- alpri0265
17 Aug 2025 16:03 #333552
by alpri0265
Replied by alpri0265 on topic Mesa card 7i90 error following
Thanks for the firmware file! When I try to flash it with mesaflash, I get the error Invalid bitfile header. It looks like this is a raw Xilinx ISE/Vivado .bit file. Could you please provide the firmware in the proper format for mesaflash (with the MESA header, or as a .bin file for the 7i90)?
Time to create page: 0.093 seconds
