Trying to build ssremote firmware for 7i90hd - now a success
- Thank you received: 422
03 Sep 2023 04:37 #279695
Trying to build ssremote firmware for 7i90hd. was created by Cant do this anymore bye all
Opened the project, added ibound.vhd & oneshot.vhd, edited the TopSSremote to suit i90 card and picked 72 pin just io file.
Come time to build I get this error:
HDLCompiler:1566 - "/home/rmurphy/Mesa/7i90/7i90/configs/hostmot2/source/hostmot2/TopSSremote.vhd" Line 524: Expression has 12 elements ; formal addr expects 11
Tried with the EPP & SPI interfaces and they went ok.
Changing line 218 in TopSSRemote.vhd
signal iabus: std_logic_vector(11 downto 0);
signal iabus: std_logic_vector(10 downto 0);
And line 491
processor: entity work.DumbAss8sqwsb
Allows to to go all the way to building a bit file. Red is original code & green is the code that builds without error. Before I flash my device I just would like to know if I'm barking up the right tree. Once again I'm experimenting on a second Spartan 6 dev board and would like it talk to the other one running the 7c81 firmware.
Rob
And line 491
Rob
- Thank you received: 5099
03 Sep 2023 14:52 - 03 Sep 2023 15:02 #279722
Replied by PCW on topic Trying to build ssremote firmware for 7i90hd.
That should be OK as long as you changed the UCF file to match your hardware
The iabus size issue is because the ROM size was increased to 4K for the 7IA0
(the 7I90ssremote ROM is onlt 2K) it should be fixed with some conditionals like:
i90ssrrom: if (BoardNameHigh = BoardName7I90) generate
i90ssr: entity work.ssremote_i90
port map(
addr => iabus(10 downto 0),
clk => procclk,
din => x"0000",
dout => idbus,
we => '0'
end generate;
iA0ssrrom: if (BoardNameHigh = BoardName7IA0) generate
ia0ssr: entity work.ssremote_ia0
port map(
addr => iabus,
clk => procclk,
din => x"0000",
dout => idbus,
we => '0'
end generate;
port map(
clk => procclk,
din => x"0000",
dout => idbus,
we => '0'
end generate;
port map(
addr => iabus,
clk => procclk,
din => x"0000",
dout => idbus,
we => '0'
end generate;
Last edit: 03 Sep 2023 15:02 by PCW.
The following user(s) said Thank You: tivoi
02 Oct 2023 12:26 #282060
Replied by Cant do this anymore bye all on topic Trying to build ssremote firmware for 7i90hd.
Wow it's been a bit of a battle.
I've managed to build the ssremote firmware, I used the sources from github.com/LinuxCNC/hostmot2-firmware, used the project file from the hostmot2 zip file that comes with the files @ mesa, added the needed files from that archive.
Now my hacked together 7i90 can discover my 7i73 (this is a genuine Mesa product) pendant (this was never an issue )& the 7i90 ssremote firmware on the Mimas.
Now to do some testing in the morning.
Thanks once again PCW for being so generous.
One question will a 25MHz clock scale up to the 100Mhz & 200 Mhz clocks ? I guess I would need a multiplier of 8 & 16 respectively. This would be used with a xc6lx16
04 Oct 2023 09:04 - 04 Oct 2023 10:04 #282258
OK I get it now after rereading the manual, just 72 GPIOs for smart serial interface.
Anything else needs the "LBP16 remote HostMot2 using the RS-422 interface".
Last edit: 04 Oct 2023 10:04 by Cant do this anymore bye all. Reason: lightbulb moment
04 Oct 2023 11:14 - 04 Oct 2023 11:36 #282268
Normal sserial has a 96 bit (96 in and 96 out) process data limit so
the 7I90ssremote uses 72 bits for GPIO and 24 bits for 3X 8 bit MPG
encoders = 96 bits in but just 72 out
SerialB has a 224 bit limit but the ssremote firmware would need to be
modified to use this.
Note that the source is there for the 7I90 and 7IA0 soft cores
but the build environment is a bit weird. The 7IA0 even has analog in
done directly by the FPGA.
Last edit: 04 Oct 2023 11:36 by PCW.
04 Oct 2023 11:53 - 04 Oct 2023 11:54 #282274
Cheers
That would be ssremote7i90.zip ?
Using the TASM assembler, I've got a file you posted regarding rebuilding the ethernet frimware, hm2_eth.zip, and messed around with makee.bat and run that under dosbox.
It seemed to run ok got some messages at the end:
Jump in conditional jump shadow at address 0075
Jump in conditional jump shadow at address 0585
Jump in conditional jump shadow at address 0650
Ran a diff on it and the date was the only difference between that & ssremote_7i90_v2.vhd.
I'll have a play tomorrow, is there any trick to getting the encoder count pins to show up ?
Once again thanks alot
:top
makeinc ssremote.inc ssremote.equ A
macro ssremote.asm > ssremote.tmp
.\Tasm -tD8ss -a -e -g3 -l -f00 -c ssremote.tmp
if errorlevel 0 goto success
goto bad
:success
echo OK!
rem pause
copy ssremote.obj ssremote.bin
makeram ssremote.bin ssremote.vhd 16 2048 SinglePort CheckJump
copy ssremote.vhd d:
goto end
:bad
echo badd badd badd badd
:end
Last edit: 04 Oct 2023 11:54 by Cant do this anymore bye all.
06 Oct 2023 08:44 #282432
Think I've got my 4x16 ports and 4 encoders, need to confirm 48=A0,49=B0,50=A1,51=B1,52=A2,53=B2,54=A3,55=B3 before hooking up hardware and chasing my tale. Took a bit of time to realise about the 10 bit address was causing some compilation errors.
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc0.count
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc0.index-enable
9 float OUT 0 hm2_7i90.0.r901.0.3.enc0.position
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc0.rawcounts
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc0.reset
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc1.count
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc1.index-enable
9 float OUT 0 hm2_7i90.0.r901.0.3.enc1.position
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc1.rawcounts
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc1.reset
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc2.count
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc2.index-enable
9 float OUT 0 hm2_7i90.0.r901.0.3.enc2.position
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc2.rawcounts
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc2.reset
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc3.count
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc3.index-enable
9 float OUT 0 hm2_7i90.0.r901.0.3.enc3.position
9 s32 OUT 0 hm2_7i90.0.r901.0.3.enc3.rawcounts
9 bit I/O FALSE hm2_7i90.0.r901.0.3.enc3.reset
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-00
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-00-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-01
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-01-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-02
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-02-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-03
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-03-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-04
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-04-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-05
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-05-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-06
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-06-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-07
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-07-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-08
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-08-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-09
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-09-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-10
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-10-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-11
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-11-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-12
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-12-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-13
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-13-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-14
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-14-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p1-in-15-not
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-00
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-01
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-02
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-03
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-04
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-05
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-06
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-07
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-08
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-09
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-10
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-11
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-12
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-13
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-14
9 bit IN FALSE hm2_7i90.0.r901.0.3.p1-out-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-00
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-00-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-01
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-01-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-02
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-02-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-03
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-03-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-04
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-04-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-05
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-05-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-06
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-06-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-07
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-07-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-08
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-08-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-09
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-09-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-10
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-10-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-11
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-11-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-12
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-12-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-13
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-13-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-14
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-14-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p2-in-15-not
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-00
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-01
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-02
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-03
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-04
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-05
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-06
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-07
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-08
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-09
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-10
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-11
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-12
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-13
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-14
9 bit IN FALSE hm2_7i90.0.r901.0.3.p2-out-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-00
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-00-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-01
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-01-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-02
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-02-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-03
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-03-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-04
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-04-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-05
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-05-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-06
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-06-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-07
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-07-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-08
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-08-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-09
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-09-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-10
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-10-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-11
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-11-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-12
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-12-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-13
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-13-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-14
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-14-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p3-in-15-not
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-00
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-01
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-02
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-03
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-04
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-05
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-06
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-07
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-08
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-09
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-10
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-11
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-12
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-13
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-14
9 bit IN FALSE hm2_7i90.0.r901.0.3.p3-out-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-00
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-00-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-01
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-01-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-02
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-02-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-03
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-03-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-04
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-04-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-05
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-05-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-06
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-06-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-07
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-07-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-08
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-08-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-09
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-09-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-10
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-10-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-11
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-11-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-12
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-12-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-13
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-13-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-14
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-14-not
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-15
9 bit OUT FALSE hm2_7i90.0.r901.0.3.p4-in-15-not
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-00
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-01
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-02
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-03
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-04
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-05
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-06
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-07
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-08
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-09
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-10
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-11
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-12
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-13
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-14
9 bit IN FALSE hm2_7i90.0.r901.0.3.p4-out-15
9 u32 RW 0x00000100 hm2_7i90.0.r901.0.3.enc0.counts-per-rev
9 float RW 1 hm2_7i90.0.r901.0.3.enc0.scale
9 u32 RW 0x00000000 hm2_7i90.0.r901.0.3.enc0mode
9 u32 RW 0x00000100 hm2_7i90.0.r901.0.3.enc1.counts-per-rev
9 float RW 1 hm2_7i90.0.r901.0.3.enc1.scale
9 u32 RW 0x00000000 hm2_7i90.0.r901.0.3.enc1mode
9 u32 RW 0x00000100 hm2_7i90.0.r901.0.3.enc2.counts-per-rev
9 float RW 1 hm2_7i90.0.r901.0.3.enc2.scale
9 u32 RW 0x00000000 hm2_7i90.0.r901.0.3.enc2mode
9 u32 RW 0x00000100 hm2_7i90.0.r901.0.3.enc3.counts-per-rev
9 float RW 1 hm2_7i90.0.r901.0.3.enc3.scale
9 u32 RW 0x00000100 hm2_7i90.0.r901.0.3.hwrevision
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-00-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-01-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-02-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-03-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-04-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-05-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-06-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-07-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-08-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-09-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-10-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-11-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-12-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-13-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-14-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p1-out-15-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-00-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-01-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-02-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-03-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-04-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-05-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-06-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-07-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-08-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-09-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-10-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-11-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-12-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-13-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-14-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p2-out-15-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-00-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-01-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-02-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-03-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-04-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-05-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-06-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-07-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-08-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-09-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-10-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-11-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-12-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-13-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-14-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p3-out-15-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-00-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-01-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-02-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-03-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-04-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-05-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-06-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-07-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-08-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-09-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-10-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-11-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-12-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-13-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-14-invert
9 bit RW FALSE hm2_7i90.0.r901.0.3.p4-out-15-invert
9 u32 RW 0x0000000F hm2_7i90.0.r901.0.3.swrevision
15 Oct 2023 11:11 - 15 Oct 2023 11:13 #283051
Replied by Cant do this anymore bye all on topic Trying to build ssremote firmware for 7i90hd - now a success
So 9 days later, three days spent debugging cos I put in a "ret" "one block of code early" and realising I had to actually edit the pin file to include the MPGs via inm entries I have a Colorlight RV901T running a modded 7i90 bitfile with modded ssremote firmware.
xorb minusoneloc was a bit of a headscratcher..........been a while since I've done any assembly (was kinda fun), but it seems to be a pretty easy to digest instruction set.
Sorry for changing the subject title tommy.
Last edit: 15 Oct 2023 11:13 by Cant do this anymore bye all.
- Thank you received: 6876
15 Oct 2023 12:00 #283057
Replied by tommylight on topic Trying to build ssremote firmware for 7i90hd - now a success
Should i change the topic for the whole topic?
15 Oct 2023 18:29 #283084
If it’s a lot of trouble no, if it’s not too much trouble that would be appreciated.
As an aside, I got 2 Spartan 6 dev boards running Mesa firmware, one connected to a RPi via SPI with the usual stepgen, encoder, GPIO and smart serial interface and a second one with 4 MPG inputs and the other 56 pins for use as either input or output. I was thinking of sharing but don’t want to be disrespectful to Pete as he supplies top products and great support, what do you think ?
I do use a few (5) Mesa boards in the mill, so I am really happy. In reality the Mesa products are a better route, simpler and less expensive than the DIY route but I had some odds and sods in the “useful box” and needed something to keep the “black dog” at bay.
Time to create page: 0.087 seconds
