Trying to build ssremote firmware for 7i90hd - now a success
15 Oct 2023 22:51 #283099 by PCW
I certainly don't mind if you share your code, I'm impressed that you
managed to successfully modify the pretty obscure and
badly commented ssremote assembly source.
The following user(s) said Thank You: Clive S, Cant do this anymore bye all
  • Cant do this anymore bye all's Avatar Topic Author
  • Platinum Member
  • Platinum Member
15 Oct 2023 23:27 #283100 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Trying to build ssremote firmware for 7i90hd - now a success
Thanks for the ok for sharing.
hahaha thanks, that's quite a compliment. There was enough comments to get the idea on what was going on.
It took a while and I really didn't want to bother you too much, the worse bit was the errant "ret" whilst setting up the mpdd records (copy & paste can be an enemy).
To tell the truth it's some impressive code considering the limited instruction set.
Took me back to the 80's when I was a teenager banging away on a little Z80 system, tho there was no assembler, everything was done by looking up opcode => hexcodes and poking into memory, and saving on cassette tape.
Even my first windows programming was in assembly.
The following user(s) said Thank You: Clive S, AlexNet
Moderators: PCW, jmelson
