Mesa configuration tool.
04 Sep 2023 15:44 #279841 by Twitchy88
Mesa configuration tool. was created by Twitchy88
Is the mesa configuration tool supposed to be used instead of pnccfg?  Totally new to linuxcnc.
  • Moderator
  • Moderator
04 Sep 2023 18:10 #279855 by tommylight
Replied by tommylight on topic Mesa configuration tool.
Try both, you can have as many configurations as you like.
And do report back what you like better, and/or if you find bugs.
Thank you.
The following user(s) said Thank You: JT, Twitchy88
04 Sep 2023 23:05 #279896 by Twitchy88
Replied by Twitchy88 on topic Mesa configuration tool.
Ok will do! I did a quick configuration with the mesa tool, and tried to open it with pncconf but it couldn't open it, so I was a bit confused if they are the same thing.   Is the mesa tool supposed to do the same thing?
  • Moderator
  • Moderator
05 Sep 2023 12:35 #279956 by tommylight
PncConf = developed by CMorley, included with LinuxCNC, easy to use for something that has to deal with thousands of different configuration options.
MCT = developed by BigJT, not yet included, easy to use, has also options for flashing the Mesa boards and some other stuff.
Both are used for making a usable configuration for LinuxCNC, both have a lot of work done by the developers and members here, and both are magnificent at what they do as it would be impossible for new users to make a configuration for thousands and thousands of different machines/controllers in use with LinuxCNC.
05 Sep 2023 14:41 #279981 by Twitchy88
Ok makes sense. I appreciate the help. I cant even begin to imagine the work that went into any of this.
The following user(s) said Thank You: tommylight, JT
Moderators: PCW, jmelson
Time to create page: 0.130 seconds
