Mesa 7i95T + 7i83 firmware needed?
- m0602232
- Thank you received: 14
11 Sep 2023 15:45 #280483
by m0602232
Mesa 7i95T + 7i83 firmware needed? was created by m0602232
Hello everybody!
This is all quite new for me so please correct me if I mix up things.
I'm trying to configure a 7i95T + 7i83 for 4 analog servo + analog spindle. Do I need specific firmware for 7i95T to enable analog outputs?
- Thank you received: 7491
11 Sep 2023 16:01 #280484
Replied by tommylight on topic Mesa 7i95T + 7i83 firmware needed?
Nope, i think not, you just need a cut CAT5 or 5E or 6 cable, plug the connector to the 7i83 and the other side with dangling wires, wire to on of Smart Serial ports.
Get the 7i95T manual first, see the color coding for wiring.
And connect the power supply also, see manual for voltage.
- m0602232
11 Sep 2023 18:15 #280485
by m0602232
Replied by m0602232 on topic Mesa 7i95T + 7i83 firmware needed?
Thanks for reply.
I got them connected and the pins in both boards are visible in Halshow. But don't I need 5 PWMGens? An error opening LinuxCNC reports that there is only one available.
- Thank you received: 5334
11 Sep 2023 18:37 #280486
Replied by PCW on topic Mesa 7i95T + 7i83 firmware needed?
The 7I83 analog outputs are addressed in HAL as 7I83 analog output pins
so no pwmgen involved.
The following user(s) said Thank You: m0602232
Time to create page: 0.124 seconds
