7i92T and 7i95T on LinuxCNC 2.9
- JT
- Thank you received: 595
16 Sep 2023 12:21 - 16 Sep 2023 12:22 #280916
by JT
7i92T and 7i95T on LinuxCNC 2.9 was created by JT
I pulled the bit of code from 2.10 to 2.9 for testing the 7i92T and 7i95T. LinuxCNC is building now on Debian 12 ATM. Trying to use 2.10 is very frustrating because it fails on both Debian 12 and Debian 13.
So far I've done this on Debian 12 to build:
JT
git clone git@github.com:LinuxCNC/linuxcnc.git emc
or
git clone https://github.com/LinuxCNC/linuxcnc.git emc
cd emc
git checkout 2.9
src/hal/drivers/mesa-hostmot2/hm2_eth.c
https://github.com/LinuxCNC/linuxcnc/commit/223837403938b43f0233e1216e65dfeb2b7cf3e4
add new code for 7i80hdt, 7i92t, 7i95t
debian/configure no-docs
dpkg-checkbuilddeps
resolve any missing dependencies
debuild -uc -us
install deb with gdebiJT
Last edit: 16 Sep 2023 12:22 by JT.
- JT
16 Sep 2023 12:26 #280917
by JT
Replied by JT on topic 7i92T and 7i95T on LinuxCNC 2.9
Well I still get OpenGl errors
JT
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 43, in __call__
return self._finalCall( *args, **named )
TypeError: 'NoneType' object is not callable
During handling of the above exception, another exception occurred:
File "/usr/bin/axis", line 3967, in <module>
get_coordinate_font(vars.dro_large_font.get())
File "/usr/bin/axis", line 3845, in get_coordinate_font
glnav.use_pango_font(coordinate_font, 0, 128)
File "/usr/lib/python3/dist-packages/glnav.py", line 65, in use_pango_font
glBitmap(1, 0, 0, 0, 0, h-d, bytearray([0]*4))
File "/usr/lib/python3/dist-packages/OpenGL/latebind.py", line 47, in __call__
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 700, in wrapperCall
raise err
File "/usr/lib/python3/dist-packages/OpenGL/wrapper.py", line 693, in wrapperCall
result = wrappedOperation( *cArguments )
File "/usr/lib/python3/dist-packages/OpenGL/platform/baseplatform.py", line 415, in __call__
return self( *args, **named )
File "/usr/lib/python3/dist-packages/OpenGL/error.py", line 230, in glCheckError
raise self._errorClass(
OpenGL.error.GLError: GLError(
err = 1285,
description = b'out of memory',
baseOperation = glBitmap,
pyArgs = (
1,
0,
0,
0,
0,
16.0,
<OpenGL.arrays._buffers.Py_buffer object at 0x7f061ac87da0>,
cArgs = (
1,
0,
0,
0,
0,
16.0,
cArguments = (
1,
0,
0,
0,
0,
16.0,
265080
265127
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
JT
- Thank you received: 7491
16 Sep 2023 12:35 #280918
Replied by tommylight on topic 7i92T and 7i95T on LinuxCNC 2.9
Can you run glxgears?
What PC and graphic card?
I got GL errors using RT kernel with new AMD proprietary drivers, included Linux drivers work perfectly with RT.
- Thank you received: 4152
16 Sep 2023 12:58 #280922
Replied by rodw on topic 7i92T and 7i95T on LinuxCNC 2.9
just in case you are missing a dependency, try:
sudo apt install -y dh-python libudev-dev docbook-xsl asciidoc ghostscript imagemagick asciidoc-dblatex bwidget intltool libboost-python-dev libepoxy-dev libgl1-mesa-dev libglu1-mesa-dev libgtk-3-dev libmodbus-dev libgpiod-dev libeditreadline-dev libusb-1.0-0-dev libxmu-dev netcat-traditional netcat-openbsd po4a python3-dev python3-tk python3-xlib tcl8.6-dev tclx tk8.6-dev yapps2 libgtk2.0-dev iptables mesa-utils python3-numpy python3-cairo python3-gi-cairo python3-opengl python3-configobj libgtksourceview-3.0-dev tcl-tclreadline python3-pyqt5 python3-pyqt5.qsci python3-pyqt5.qtsvg python3-pyqt5.qtopengl python3-opencv python3-dbus python3-espeak python3-dbus.mainloop.pyqt5 espeak-ng pyqt5-dev-tools gstreamer1.0-tools espeak python3-poppler-qt5 python3-pyqt5.qtwebengine python3-pyqt5.qtwebkit xvfb python3-serial
16 Sep 2023 13:01 #280923
John, also seb;s new buildbot lets you grab 2.9 or 2.10 without building form source
buildbot2.highlab.com/
The 2.9 getting linuxcnc docs show you how to set the repos up so its simple to upgrade linuxcnc and you just need to modify the sources.list to get master branch
- JT
16 Sep 2023 15:26 #280932
by JT
Yes I can run glxgears and 2.9 worked before from the debian repo
I'll try the buildbot to see if that's better.
JT
JT
- JT
16 Sep 2023 17:11 #280934
by JT
JT
I only see 2.9 and older in the buildbot2, have you seen 2.10?John, also seb;s new buildbot lets you grab 2.9 or 2.10 without building form source
JT
- JT
16 Sep 2023 18:43 #280940
by JT
When I install the 2.9 from buildbot I get the following error again.
JT
Debug file information:
note: MAXV max: 5.000 units/sec 300.000 units/min
note: LJOG max: 5.000 units/sec 300.000 units/min
note: LJOG default: 0.250 units/sec 15.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
raise err
err = 1285,
pyArgs = (
1,
0,
0,
0,
0,
16.0,
<OpenGL.arrays._buffers.Py_buffer object at 0x7f2a1b2d7da0>,
cArgs = (
1,
0,
0,
0,
0,
16.0,
cArguments = (
1,
0,
0,
0,
0,
16.0,
272789
272841
JT
- JT
16 Sep 2023 18:46 #280942
by JT
So I uninstalled the buildbot version of 2.9 and apt auto-remove then install the debian version of 2.9 and it works so something is very broken now.
JT
JT
16 Sep 2023 22:47 #280953
Always this error, so the opengl version for python is having a hiatus, the normal opengl is working ok as glxgears run ok/usr/lib/python3/dist-packages/OpenGL/error.py
