7i92T and 7i95T on LinuxCNC 2.9
16 Sep 2023 23:06 #280956 by rodw
Replied by rodw on topic 7i92T and 7i95T on LinuxCNC 2.9
John the buildbot gets 2.10 if you change the sources.list if you replace the  line with 2.9 uspace with master-uspace in the sources.list eg.
deb buildbot2.highlab.com/debian/ bookworm master-uspace
You can also navigate to the debs and install the debs manually in that case I have done
sudo apt remove linucnc-uspace linuxcnc-uspace-dev
Then manually install the downloaded packages
sudo dpkg -i  linuxcnc-uspace(tab)
sudo dpkg -i linuxcnc-uspace-dev(tab)
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
23 Sep 2023 13:00 #281470 by JT
Replied by JT on topic 7i92T and 7i95T on LinuxCNC 2.9
Peter added support for the 7i95T to 2.9 so I need to pull and build that to test. I "think" Andy also fixed the open gl error last night as well as the M4 issue.
JT
23 Sep 2023 22:34 #281511 by rodw
JT
Yes, andy backported the fix for opengl to 2.9 yesterday
I have rebuilt my installer
drive.google.com/file/d/1s2Te9JtXxb8yB9r.../view?usp=drive_link
but that does not really matter becasue on an apt updade && apt upgrade it will get the latest lcnc version from the buildbot
  • JT
  • Administrator
  • Administrator
24 Sep 2023 12:02 #281543 by JT
JT
Tested 2.9 and 2.10 and both work almost. Looks like a pin has been removed in 2.10 but the sim's have not been updated so they fail to run. But NO opengl errors!
JT
24 Sep 2023 20:31 #281562 by rodw
Great.
What pin is missing and what sim?
  • Moderator
  • Moderator
24 Sep 2023 23:57 #281568 by tommylight
Replied by tommylight on topic 7i92T and 7i95T on LinuxCNC 2.9
A pin with "lube" something, probably, i think Aciera mentioned it on another thread.
  • JT
  • Administrator
  • Administrator
25 Sep 2023 12:11 #281592 by JT
I'm back on 2.9 but Tommy is correct a lube pin. Easy enough to test just run Axis in 2.10.
JT
25 Sep 2023 19:22 #281608 by rodw
Yes, I found the commit in git
Moderators: PCW, jmelson
Time to create page: 0.481 seconds
