Simple mesa rpi g540 question
22 Sep 2023 09:13 #281356 by muamerb
Simple mesa rpi g540 question was created by muamerb
Is this god combo?
mesa7i92tf
gecko g540
raspberry pi 4 8gb
Struggling to find a good answer to this simple question :)
  • Platinum Member
  • Platinum Member
22 Sep 2023 09:26 #281357 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Simple mesa rpi g540 question
It'll work.
The following user(s) said Thank You: muamerb
  • Moderator
  • Moderator
22 Sep 2023 17:06 #281393 by tommylight
Replied by tommylight on topic Simple mesa rpi g540 question
For what?
What reduction?
Mesa and RPI are OK, the questions are regarding G540.
28 Sep 2023 06:27 #281771 by muamerb
Replied by muamerb on topic Simple mesa rpi g540 question
Hei thank you for reply.
First if all sorry that my post was simple. So I will expand my post with some extra words. :)
I have a machine that I builded for 10 years ago and was always running machine with a regular pc that has some form for linuxcnc.
At the moment latency is a issue and I decided to change system. I still use the same g540 :) the thing just unbreakable.
Issue so far is that I never used a raspberry pi before. And i am struggling now to instal a version that will work. i tried so far with official Linuxcnc system image for raspberry pi and stoped right at the boot. Some error about old operating system. I saw it was discussed in some thread.
I tried other way. Installed raspberry os and there got error apt-get not allowed anymore. :) do you guys have a link where I can find instructions how to instal linuxcnc on raspberry pi 4 (8 gb).
Little bit about my machine.
It is small but capable of machining softer metals like alu.
Dual x axis and z axis 3a motor
Y axis 3,5a motor
24v power supply
Wj220 vfd running 1,5kw spindle
G540 controls everything.
28 Sep 2023 07:53 #281774 by rodw
29 Sep 2023 22:07 - 29 Sep 2023 22:09 #281889 by JT
Replied by JT on topic Simple mesa rpi g540 question
Why not use the PC you have? I have one machine that uses Ubuntu 10.04 with Mesa 5i20 and some version of EMC.
With the 7i92T you will need Linuxcnc 2.9 if I recall correctly.
JT
Last edit: 29 Sep 2023 22:09 by JT.
01 Oct 2023 16:52 #282000 by muamerb
Hei
Thanks for reply and input.
The reason is simple I have a raspberry pi and a touch screen and it is tempting a option that has small footprint. It just sounds so rlegant to have a small box with touch screen to control my machine.
I didnt buy any mesa card yet but i am exploring different options. My current setup is still ok and working but i need to change something soon. Last pc I had was so bad that on the end my motors was blocked in the middle of operation.
I guess running thru parallel port is not option for the future.
My personal problem is that i am more of mechanical guy and each time i need to do something with system i forget what i did :) and need to kind of learn things again ;)
But there is usually a lot information on this forum and community is very helpful and active. At the momet i am learning about ppf setup and mesa cards.
Grateful for answers here.
Moderators: PCW, jmelson
Time to create page: 0.655 seconds
