7I84 Max Input Frequency
3 years 1 month ago #281531 by nwallace
I have a situation where I need to be able to read a 24v sensor up to about 1000hz. Does anyone know if the inputs on a 7I84 are capable of reading that?
3 years 1 month ago #281535 by rodw
Replied by rodw on topic 7I84 Max Input Frequency
the manual says 10 kHz (10,000 Hz)
3 years 1 month ago #281536 by nwallace
Replied by nwallace on topic 7I84 Max Input Frequency
Thanks! I looked through it and just didn't see it.
3 years 1 month ago #281551 by tommylight
Replied by tommylight on topic 7I84 Max Input Frequency
10KHz would require a 100000ns servo period, i have gone to 250000 and that worked perfectly through Ethernet and PCI-E.
3 years 1 month ago #281564 by rodw
I nearly said earlier that you might be better off using an encoder input which is what is done when using a THCAD.
You can scale the resulting velocity in hal
That way its not dependent on the servo thread.
3 years 1 month ago #281567 by tommylight
I thing PCW mentioned that can do 10MHz, i have tested a bit over 1MHz, did not have anything faster. :(
Moderators: PCW, jmelson
Time to create page: 0.175 seconds
