Lost on Hal with 7i94 and 7i88
- MrMick
26 Sep 2023 22:11 #281669
by MrMick
Replied by MrMick on topic Lost on Hal with 7i94 and 7i88
Haven't seen a change on step have been using halshow for direction no change both stay red
- Thank you received: 4152
26 Sep 2023 22:14 #281670
Replied by rodw on topic Lost on Hal with 7i94 and 7i88
You can't really see anything with fine resolution in halshow. You may need halscope for that.
- MrMick
26 Sep 2023 22:21 #281671
by MrMick
I've only been using Hal for direction, tried the scope on Step pins. Everything else shows like position cmd postion fb velocity fb no velocity cmd tho due to step type.
I do have the 7I85s on the shelf I ordered with the 7i88 but think its a what I've done problem. Nothing showing on the scope. I'm no expert on scopes but managed it before with grbl ect. Tried a lot so far just seem to be going around in circles and not really making progress, latest trial was with a hm stepper example but you'll see what else I tried below that nulled out
- Thank you received: 5334
26 Sep 2023 22:39 #281674
Replied by PCW on topic Lost on Hal with 7i94 and 7i88
Does GPIO41 show up as low in halshow?
Can you check if there has been a watchdog bite?
- MrMick
26 Sep 2023 22:54 #281675
by MrMick
No alarm on watch dog, or no watch dog bite. Have increased time on that earlier.
hm2.7i94.gpio.041.in low
hm2.7i94.gpio.041.in_not high
hm2.7i94.gpio.041.out low
26 Sep 2023 23:11 - 26 Sep 2023 23:12 #281676
Actually I cannot see how that hal file would even load with:
num_encoders=8
num_encoders=8
Last edit: 26 Sep 2023 23:12 by PCW.
- MrMick
26 Sep 2023 23:23 #281677
by MrMick
Just changed back to zero, had tried that before
Now
gpio 41 invert_output low
gpio 41 is_opendrain low
gpio is_output high
Now
gpio is_output high
26 Sep 2023 23:27 - 26 Sep 2023 23:33 #281678
Wait a second, a hal file with 8 encoders would not even load.
Are you sure the hal file you are editing is the one you are running?
I would expect something like this to happen if you specify more resources than available:
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
hm2/hm2_7i96s.0: config.num_encoders=2, but only 1 are available, not loading driver
hm2/hm2_7i96s.0: failed to parse Module Descriptor 6
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2_eth: rtapi_app_main: Invalid argument (-22)
./hm2-pidstepper.hal:43: waitpid failed /home/pcw/linuxcnc-dev/bin/rtapi_app hm2_eth
./hm2-pidstepper.hal:43: /home/pcw/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./hm2-pidstepper.hal:43: insmod for hm2_eth failed, returned -1
hm2: unloading
hm2: unloading
Last edit: 26 Sep 2023 23:33 by PCW.
- MrMick
26 Sep 2023 23:29 #281679
by MrMick
Yes, I had originally changed to zero but I'll go double check number never made a difference, I didn't realise it'd effect it as later I'd like to fit it to the sserial for my index pulse but thats after I get it stepping
- MrMick
26 Sep 2023 23:41 #281680
by MrMick
Loads with encoders or not here's the terminal start text
I'm not using ladder atm
Time to create page: 0.233 seconds
