Mesa 7i76 Frimware
25 Sep 2023 08:52 #281584 by holziCNC
Mesa 7i76 Frimware was created by holziCNC
Hello together,
I am trying to update my Mesa 7i76 but unfortunately I get the following error. Does anyone have a solution
ove 7I76 W3 to right hand position
cycle 7I76 field power and hit return
halcmd: /opt/Xilinx/14.7/ISE_DS/ISE/lib/lin64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by halcmd)
halcmd: /opt/Xilinx/14.7/ISE_DS/ISE/lib/lin64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by halcmd)
halcmd: /opt/Xilinx/14.7/ISE_DS/ISE/lib/lin64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /lib/liblinuxcncini.so.0)
halcmd: /opt/Xilinx/14.7/ISE_DS/ISE/lib/lin64/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /lib/liblinuxcncini.so.0)
halcmd: /opt/Xilinx/14.7/ISE_DS/ISE/lib/lin64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /lib/liblinuxcncini.so.0)
Note: Using POSIX realtime
now move 7I76 W3 to the left hand position
and cycle field power
25 Sep 2023 15:08 #281599 by PCW
Replied by PCW on topic Mesa 7i76 Frimware
What command did you use to update the 7I76 firmware?
Xilinx tools are not related in any way to updating the 7I76 firmware
Also you should only update 7I76 firmware if LinuxCNC complains about the 7I76 firmware version
26 Sep 2023 12:44 #281646 by holziCNC
Replied by holziCNC on topic Mesa 7i76 Frimware
The problem was due to old dependencies I had set in my .bashrc file.
Moderators: PCW, jmelson
Time to create page: 0.189 seconds
