Error when starting linuxcnc
- arthurcloet
30 Sep 2023 09:03 #281914
by arthurcloet
Error when starting linuxcnc was created by arthurcloet
Hello,
I bought an old router, so the controller is "flintstone", signed Fred
Then i installed linux and linuxcnc on a separate pc, hooked a Mesa card 7I96S via ethernet to it.
Running linux pncconfig is no probem, there are even some LEDs reacting. The file was saved (properly I think)
Then I tried running linuxcnc and came the errors. The error report is found as attachment.
Could somebody send me in the right direction where to find the answers?
Kind regards,
Arthur Cloet
Kind regards,
Arthur Cloet
- Thank you received: 7491
30 Sep 2023 12:21 #281929
Replied by tommylight on topic Error when starting linuxcnc
Make a new config that uses Axis GUI, see if that works.
Mesa seems to be found and working, but GmoccaPy fails for some reason.
- Thank you received: 5334
30 Sep 2023 14:55 - 30 Sep 2023 14:55 #281938
Replied by PCW on topic Error when starting linuxcnc
This also must be a quite old version (pre 2.8.4) of LinuxCNC:
hm2_eth: Unrecognized ethernet board found: 7I96S -- port names will be wrong
The 7I96S is supported in LinuxCNC 2.8.4 and greater
Last edit: 30 Sep 2023 14:55 by PCW.
- arthurcloet
01 Oct 2023 08:09 #281969
by arthurcloet
Replied by arthurcloet on topic Error when starting linuxcnc
Thanks; I shall try this soon!
Time to create page: 0.333 seconds
