LitexCNC: firmware and driver for 5A-75B and 5A-75E
2 years 5 months ago #299805 by Ehsan_R
For this to work, you would have to have actual feedback from the encoder
(connected in hal) or firmware that supports a stepgen index input
It might be possible to do this in software (hal) but it would be fairly complex
The fact is that I do not have much expertise in using Linux CNC.
Is it possible for you to guide me in doing this?
2 years 5 months ago #299806 by Ehsan_R
I encountered a strange problem while using Litex for some time.
This problem is that when I close the linuxcnc software or disable the machine power key, the motors automatically start moving at a very low speed.
Does anyone know how to fix this?
Does anyone have a solution for this problem?
2 years 5 months ago #299808 by tommylight
I did, you ignored it.
Short cables, shielded preferably, properly grounded.
2 years 5 months ago #299811 by PCW
If the firmware does not support index homing on stepgen systems, it's a bit complex because
you now must setup a PID loop using encoder feedback and use the stepgen in velocity mode.
You could use a pncconf created configuration as a sample of this kind of hal setup.
You might ask if LitexCNC firmware can support index input on stepgen systems, because
this would be a much simpler path if that can be done.
2 years 5 months ago #299814 by Ehsan_R
Do you believe this is due to the effects of noise?
So how does the watchdog work?
Shouldn't all functions of the board stop quickly after disconnecting the board and the software?
2 years 5 months ago #299816 by Ehsan_R
Thank you for your reply
I will do this solution and tell you the result
Moderators: PCW, jmelson
Time to create page: 0.467 seconds
