Then everything should be up to date for me now.
I have compiled and flashed the JSON once with 2 PWM generators + 6 step generators and then again without PWM generators.
Neither variant brought any improvement with regard to the fifth axis.
Here again the output when calling Linuxcnc and attempting to home the axes.
cnc@raspberrypi:~$ linuxcnc
LINUXCNC - 2.9.2
Machine configuration directory is '/home/cnc/linuxcnc/configs/test1'
Machine configuration file is 'test1.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./test1.hal
identityKinematicsSetup: coordinates:XYYZA
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
Joint 4 ==> Axis A
litexcnc: Loading Litex CNC driver version 1.1.0
litexcnc: Loading and registering default modules:
litexcnc: Registered module gpio
litexcnc: Registered module pwm
litexcnc: Registered module encoder
litexcnc: Registered module step
litexcnc: Setting up board drivers:
litexcnc: Registered driver eth
LitexCNC-eth: connected to board on '10.0.0.10:1234'
litexcnc: Setting up modules...
litexcnc: Reading 28 bytes
litexcnc: - Watchdog
litexcnc: - Wallclock
litexcnc: - gpio ... done!
litexcnc: - encoder ... done!
litexcnc: - step ... done!
litexcnc: Creating read and write buffers...
litexcnc: Base addresses: init: 00000000, reset: 0000003C, config: 00000040, write: 00000044, read: 0000008C
litexcnc: - Write buffer: 72 bytes
litexcnc: - Read buffer: 96 bytes
litexcnc: Exporting functions...
Found file(REL): ./custom.hal
litexcnc/5A-75B:V8.0: Watchdog timeout (3000000 ns) is dangerously short compared to litexcnc_write() period (2400000 ns)
note: MAXV max: 25.000 units/sec 1500.000 units/min
note: LJOG max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 2.500 units/sec 150.000 units/min
note: AJOG max: 25.000 units/sec 1500.000 units/min
note: AJOG default: 25.000 units/sec 1500.000 units/min
Warning: Forward kinematics must handle duplicate coordinate letters:yy
note: jog_order='XYZA'
note: jog_invert=set()
task: main loop took 0.128303 seconds
joint 4 following error
emc/task/taskintf.cc 976: Error on joint 4, command number 136
Cannot unhome while homing, joint 4Cannot unhome while homing, joint 4
task: main loop took 0.141973 seconds
task: 6506 cycles, min=0.000033, max=0.141973, avg=0.010151, 2 latency excursions (> 10x expected cycle time of 0.010000s)
litexcnc: LitexCNC driver unloaded
Ps: I did not reinstall the toolchain, as this was not explicitly requested
