Could you also try with two less PWMs to see whether this resolves the issue with the stepgen:
"board_name": "5A-75B:V8.0",
"board_type": "5A-75B v8.0",
"clock_frequency": 40000000,
"connection": {
"connection_type": "etherbone",
"tx_delay": 0,
"ip_address": "10.0.0.10",
"mac_address": "0x10e2d5000000"
"watchdog": {
"pin":"j1:8"
"modules": [
"module_type": "gpio",
"instances": [
{"direction": "out", "pin":"j1:9", "name":"j1:10"},
{"direction": "out", "pin":"j1:10", "name":"j1:11"},
{"direction": "out", "pin":"j1:11", "name":"j1:12"},
{"direction": "out", "pin":"j1:12", "name":"j1:13"},
{"direction": "out", "pin":"j1:13", "name":"j1:14"},
{"direction": "out", "pin":"j1:14", "name":"j1:15"},
{"direction": "in", "pin":"j1:0", "name":"j1:1" },
{"direction": "in", "pin":"j1:1", "name":"j1:2" },
{"direction": "in", "pin":"j1:2", "name":"j1:3" },
{"direction": "in", "pin":"j1:4", "name":"j1:5" },
{"direction": "in", "pin":"j1:5", "name":"j1:6" },
{"direction": "in", "pin":"j1:6", "name":"j1:7" },
{"direction": "in", "pin":"j2:0", "name":"j2:1" },
{"direction": "in", "pin":"j2:1", "name":"j2:2" },
{"direction": "in", "pin":"j2:2", "name":"j2:3" },
{"direction": "in", "pin":"j2:4", "name":"j2:5" },
{"direction": "in", "pin":"j2:5", "name":"j2:6" },
{"direction": "in", "pin":"j2:6", "name":"j2:7" },
{"direction": "out", "pin":"j5:0", "name":"j5:1" },
{"direction": "out", "pin":"j5:1", "name":"j5:2" },
{"direction": "out", "pin":"j5:2", "name":"j5:3" },
{"direction": "out", "pin":"j5:4", "name":"j5:5" },
{"direction": "out", "pin":"j5:5", "name":"j5:6" },
{"direction": "out", "pin":"j5:6", "name":"j5:7" }
"module_type": "pwm",
"instances": [
{"pin":"j6:0", "name":"j6:1"},
{"pin":"j6:1", "name":"j6:2"},
{"pin":"j6:2", "name":"j6:3"},
{"pin":"j6:4", "name":"j6:5"}
"module_type": "encoder",
"instances": [
{"pin_A":"j3:0", "pin_B":"j3:1"},
{"pin_A":"j3:2", "pin_B":"j3:4"},
{"pin_A":"j3:5", "pin_B":"j3:6"},
{"pin_A":"j4:0", "pin_B":"j4:1"},
{"pin_A":"j4:2", "pin_B":"j4:4"},
{"pin_A":"j4:5", "pin_B":"j4:6"}
"module_type": "stepgen",
"instances": [
"pins" : {
"stepgen_type": "step_dir",
"step_pin": "j7:0",
"dir_pin": "j7:1"
"soft_stop": true
"pins" : {
"step_pin": "j7:2",
"dir_pin": "j7:4"
"soft_stop": true
"pins" : {
"step_pin": "j7:5",
"dir_pin": "j7:6"
"soft_stop": true
"pins" : {
"step_pin": "j8:0",
"dir_pin": "j8:1"
"soft_stop": true
"pins" : {
"step_pin": "j8:2",
"dir_pin": "j8:4"
"soft_stop": true
"pins" : {
"step_pin": "j8:5",
"dir_pin": "j8:6"
"soft_stop": true
Still have to find out why 120 bytes gives a n error on FPGA. The buffer depth is 255 bytes (including 16 bytes header), so it should have some leeway there...
