LitexCNC: firmware and driver for 5A-75B and 5A-75E
2 years 9 months ago #290810 by uba100
The configuration actually seems to be OK. I can't find any errors in the 5a-75b_v8.0_i12o14p6s6e6.json.
2 years 9 months ago #290912 by TOLP2
The configuration was not OK, my apologies.
The cause is that I changed the config because of a changed watchdog. I forgot however to remove the pin used in the watchdog in the GPIO out. this means a pin was used twice in the config, leading to errors.
I have changed the configuration files in the documentation, or you can remove the line:
                {"direction": "out", "pin":"j1:8" , "name":"j1:9" },
from the configuration file.
I messed up with a commit, my apologies.
2 years 9 months ago #290916 by uba100
Thank you very much,
it works now. The firmware has been successfully created. Flashing the firmware to the board was also reported as successful. I will test whether it works in the next few days. I did not get a V8.0 but a V8.2 when I bought it. However, when comparing my board with the V8.0 described on the Internet, I could not find any differences in the hardware. The apparently successful flashing process also seems to confirm this.
Best regards
The following user(s) said Thank You: TOLP2
2 years 9 months ago - 2 years 9 months ago #290927 by TOLP2
The v6.x, v8.0 and v8.2 are identical, so no changes are required to your board or config.
Thank you for helping resolving this issue.
Last edit: 2 years 9 months ago by TOLP2.
2 years 9 months ago #290963 by uba100
I have tried to connect to the board.
As you can see, I can successfully ping the board after flashing. So I think that the flashing was successful,
cnc@raspberrypi:~$ ping -c 5 10.0.0.10
PING 10.0.0.10 (10.0.0.10) 56(84) bytes of data.
64 bytes from 10.0.0.10: icmp_seq=1 ttl=128 time=0.257 ms
64 bytes from 10.0.0.10: icmp_seq=2 ttl=128 time=0.149 ms
64 bytes from 10.0.0.10: icmp_seq=3 ttl=128 time=0.164 ms
64 bytes from 10.0.0.10: icmp_seq=4 ttl=128 time=0.175 ms
64 bytes from 10.0.0.10: icmp_seq=5 ttl=128 time=0.162 ms
--- 10.0.0.10 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4080ms
rtt min/avg/max/mdev = 0.149/0.181/0.257/0.038 ms
cnc@raspberrypi:~$
The Litexcnc driver can also be loaded in halrun.
cnc@raspberrypi:~$ halrun
halcmd: loadrt litexcnc
Note: Using POSIX realtime
litexcnc: Loading Litex CNC driver version 1.1.0
litexcnc: Loading and registering default modules:
litexcnc: Registered module gpio
litexcnc: Registered module pwm
litexcnc: Registered module encoder
litexcnc: Registered module step
halcmd:
But the connection to the board via eth does not work.
halcmd: loadrt litexcnc_eth connections="eth:10.0.0.10"
Unknown parameter `connections=eth:10.0.0.10'
<stdin>:4: waitpid failed /usr/bin/rtapi_app litexcnc_eth
<stdin>:4: /usr/bin/rtapi_app exited without becoming ready
<stdin>:4: insmod for litexcnc_eth failed, returned -1
halcmd:
Have I forgotten a step?
2 years 9 months ago #290968 by uba100
I must apologize.
I read the command: "litexcnc_eth" incorrectly from a forum.
The first command is correct:
"loadrt litexcnc" to append the "connections=eth:10.0.0.10".
Then the output looks better.
halcmd: loadrt litexcnc connections="eth:10.0.0.10"
litexcnc: Setting up board drivers:
litexcnc: Registered driver eth
LitexCNC-eth: connected to board on '10.0.0.10:1234'
litexcnc: Setting up modules...
litexcnc: Reading 36 bytes
litexcnc: - Watchdog
litexcnc: - Wallclock
litexcnc: - gpio ... done!
litexcnc: - pwm ... done!
litexcnc: - encoder ... done!
litexcnc: - step ... done!
litexcnc: Creating read and write buffers...
litexcnc: Base addresses: init: 00000000, reset: 00000044, config: 00000048, write: 0000004C, read: 000000C8
litexcnc: - Write buffer: 124 bytes
litexcnc: - Read buffer: 96 bytes
litexcnc: Exporting functions...
Moderators: PCW, jmelson
Time to create page: 0.401 seconds
