Thank you very much for your help.
Now it seems to work.
To be on the safe side, I reinstalled the image on the SD card and followed all the steps as described in the documentation here
litex-cnc.readthedocs.io/en/latest/raspberrypi.html
described here.
After reading these lines here:
# set PATH so it includes oss-cad-suite
if [ -d "/home/cnc/toolchain/oss-cad-suite/bin" ] ; then
PATH="/home/cnc/toolchain/oss-cad-suite/bin:$PATH"
fi
in my /.bashrc, the compilation of the JSON file seems to work.
I do get the error message at the end:
ERROR: Cell 'watchdog0$tr_io' cannot be bound to bel 'X0/Y44/PIOD' since it is already bound to cell 'gpio_out0$tr_io'
0 warnings, 1 error
File "/home/cnc/.local/bin/litexcnc", line 8, in <module>
sys.exit(cli())
File "/home/cnc/.local/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
return self.main(*args, **kwargs)
File "/home/cnc/.local/lib/python3.11/site-packages/click/core.py", line 1078, in main
rv = self.invoke(ctx)
File "/home/cnc/.local/lib/python3.11/site-packages/click/core.py", line 1688, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/cnc/.local/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/cnc/.local/lib/python3.11/site-packages/click/core.py", line 783, in invoke
return __callback(*args, **kwargs)
File "/home/cnc/.local/lib/python3.11/site-packages/litexcnc/cli/build_firmware.py", line 58, in cli
builder.build(run=build)
File "/home/cnc/toolchain/litex/litex/litex/soc/integration/builder.py", line 350, in build
vns = self.soc.build(build_dir=self.gateware_dir, **kwargs)
File "/home/cnc/toolchain/litex/litex/litex/soc/integration/soc.py", line 1205, in build
return self.platform.build(self, *args, **kwargs)
File "/home/cnc/toolchain/litex/litex/litex/build/lattice/platform.py", line 43, in build
return self.toolchain.build(self, *args, **kwargs)
File "/home/cnc/toolchain/litex/litex/litex/build/lattice/trellis.py", line 236, in build
_run_script(script)
File "/home/cnc/toolchain/litex/litex/litex/build/lattice/trellis.py", line 174, in _run_script
raise OSError("Error occured during Yosys/Nextpnr's script execution.")
OSError: Error occured during Yosys/Nextpnr's script execution.
But this seems to me to be an error in the example file 5a-75b_v8.0_i12o14p6s6e6.json.
