Is it possible to define which pins on a 7i92 an encoder uses?
- Thank you received: 5334
22 Oct 2023 23:09 #283544
Replied by PCW on topic Is it possible to define which pins on a 7i92 an encoder uses?
So if put a G540 on P1 +some MPG inputs on P2 that would work?
- trainwreck
- Thank you received: 6
23 Oct 2023 12:56 #283598
by trainwreck
Replied by trainwreck on topic Is it possible to define which pins on a 7i92 an encoder uses?
First, sorry for my consistently delayed responses. For some reason I can't actually post to this forum from any of my computers or phones except for my linux pc in my basement that is running linuxcnc.
I don't think I fully understand what you're saying. Currently my G540 is on P1 and the 7i75 is on P2, and unfortunately that is really the only realistic configuration for them due to control cabinet layout. The problem I have is that encoder0 is also on P1 according to mesaflash when I run --readhmid, but those pins are already in use by my limit switches. I can't move my limit switches to the 7i75 because they are running on 12V and the manual for that card specifically states NOT to connect continuous 12V to the inputs.
23 Oct 2023 15:23 #283607
7I92 config with G540 on P1 and 2 full encoders + up to 4 MPG encoders on P2
pinned out for 7I75 so encoder/MPG pins do not straddle between TB2 and TB3
The following user(s) said Thank You: trainwreck
- trainwreck
23 Oct 2023 18:07 #283626
by trainwreck
Wow, this is the second time you've provided me with custom firmware! Thank you so much!
Is there documentation you can point me to for how to do this myself so if for some reason I need to do it again I can figure it out rather than need to bug you/the forums?
23 Oct 2023 19:26 #283634
Tom Light's old page has the basics:
tom-itx.no-ip.biz:81/~webpage/emc/xilinx...14_install_index.php
- trainwreck
23 Oct 2023 21:12 #283638
by trainwreck
Thanks for everything PCW, the new firmware worked like a charm and the pendant is working now
Time to create page: 0.245 seconds
