Use glass scales with 7i96S for closed loop feedback
21 Oct 2023 16:50 - 21 Oct 2023 18:57 #283448 by MachNegativeOne
On my RF45 Mill I have a DRO with glass scales.    I would like to know if I can use them with the 7i96S and my stepper motors for a closed loop system.  I understand that I can interface the scales to the 7i69S with a 7I85 or 7I85S and a DB25 cable.
My scales are Ditron DC10 with  .005mm resolution.  My calculations are as follows: The scales are 60m/min max working speed, which is 1m/sec@ 5um, that is  200,000 counts/sec .As it is a quadrature count of A/B, each channel is max 50Khz
So would this be fast enough for a closed loop system?  Or should I just use them for some other form of position verification.
thanks for the help
Last edit: 21 Oct 2023 18:57 by MachNegativeOne.
  • Moderator
  • Moderator
21 Oct 2023 21:33 #283459 by tommylight
Short answer,
Yes easily.
Long answer will have to wait for someone else to chime in, or i will later, sorry.
The following user(s) said Thank You: MachNegativeOne
  • Moderator
  • Moderator
22 Oct 2023 00:47 #283471 by tommylight
OK, Mesa can count much more than 50KHz, so for normal quadrature TTL level 5V encoders or glass scales you would need a Mesa 7i85 or 7i85S, one has Smart serials and encoders, the other has stepgens and encoders, i would go for smart serial as you already have 5 stepgens on Mesa 7i96S, both can probably do differential and single ended wiring.
I think there is already firmware made for such a combo, flashing it takes a single line and a minute of time.
22 Oct 2023 00:49 #283472 by MachNegativeOne
Replied by MachNegativeOne on topic Use glass scales with 7i96S for closed loop feedback
Thanks very much for the help.
p.s. love the avatar image - the pup looks like a fun one!
  • Moderator
  • Moderator
22 Oct 2023 01:28 #283474 by tommylight
You are welcomed, always.
Yes, the pup was fun, chewing on my foot every day, and strangely, never ever bit hard to scratch the shoes. :)
Moderators: PCW, jmelson
Time to create page: 0.496 seconds
