5i24-25
- BGM1956
31 Oct 2023 12:11 #284173
by BGM1956
5i24-25 was created by BGM1956
I am retrofitting a Bridgeport V2XT. It has analog servos and drives installed. Currently it does not have a spindle motor. I am thinking of using a 5i24-25 & a 7i48 card. My questions are:
1. Is there any problem lurking using this combination?
2. I am planning on using a VFD to drive the spindle motor, do I configure one of the analog servo outputs to drive the VFD and use the encoder input
for rigid tapping?
3. The 5i24-25 has 3.3v IO's, is it better to use the 3.3 through the switches or 12 or 24 volt and opto-isolators?
4. I would like to have a feed rate override potentiometer on the front panel, since the IO's don't recognize analog inputs, what is the easiest way
to do this?
for rigid tapping?
to do this?
- Thank you received: 5334
31 Oct 2023 14:04 #284186
Replied by PCW on topic 5i24-25
I would suggest a 7I97 or 7I97T instead
(we should have some 7I97Ts soon)
- BGM1956
31 Oct 2023 16:13 #284198
by BGM1956
Replied by BGM1956 on topic 5i24-25
Thank you, A card like that was my first choice but everyone shows them out of stock, If it's permissible to ask, who are you with? Can you message me when they become available?
31 Oct 2023 21:01 #284219
You can send an email to Mesa Electronics asking to be put on a list for the first 7I97T cards
The following user(s) said Thank You: BGM1956
Time to create page: 0.108 seconds
