LinuxCNC error
- tda2261
31 Oct 2023 20:18 #284208
by tda2261
LinuxCNC error was created by tda2261
I am getting an error code when loading up LinuxCNC. I have the mesa boards installed. Error code: ' /usr/realtime-3.4.55-rtai-2/modules/linuxcnc/hm2_7i43.ko' : -1 Input/output error. could someone help me troubleshoot the error?
- tda2261
31 Oct 2023 20:19 - 31 Oct 2023 20:22 #284210
by tda2261
Replied by tda2261 on topic LinuxCNC error
let me know if you need any images
Last edit: 31 Oct 2023 20:22 by tda2261.
- Thank you received: 7491
31 Oct 2023 20:33 #284213
Replied by tommylight on topic LinuxCNC error
Error report, especially the debug part.
- tda2261
01 Nov 2023 11:30 #284246
by tda2261
01 Nov 2023 12:47 #284250
Moved to "driver boards".
- Thank you received: 5334
01 Nov 2023 13:59 #284258
Replied by PCW on topic LinuxCNC error
LinuxCNC did not find the 7I43 card.
some possible causes are:
7I43 not in EPP mode (7I43 jumper setting)
No 5V power to 7I43
Bad 7I43
Bad parallel cable or 7I43 not connected
Parallel port not in EPP 1.9 mode (BIOS setting)
Bad parallel port
No 5V power to 7I43
Bad 7I43
Bad parallel port
- tda2261
02 Nov 2023 13:59 #284328
by tda2261
How do I check or change it into EPP mode?
02 Nov 2023 14:16 #284330
On the BIOS it depends but there is usually an I/O setup section
and you can select the parallel port address and operational mode.
Is the 7I43 connected to a motherboard parallel port connector?
On the 7I43, W4 and W5 down,How do I check or change it into EPP mode?
- tda2261
02 Nov 2023 15:13 #284337
by tda2261
I found that it was in ECP mode in BIOS. I changed it EPP.
The board looks correct, do i need to change anything?
- tda2261
02 Nov 2023 15:41 #284340
by tda2261
i am still getting an error after
Time to create page: 0.219 seconds
