Creating custom configs for Mesa 7i80HDT
- slammers
01 Nov 2023 18:12 - 01 Nov 2023 18:14 #284274
by slammers
Creating custom configs for Mesa 7i80HDT was created by slammers
Does anyone have a guide for how to compile the Mesa provided source files for the Trion FPGAs on the 7i80HDT?
Last edit: 01 Nov 2023 18:14 by slammers.
- Thank you received: 5334
01 Nov 2023 18:54 #284275
Replied by PCW on topic Creating custom configs for Mesa 7i80HDT
The process is basically the same as for Xilinx based boards except
for using a different tool chain. That is, you use an existing pinout file
or create a new one, reference the new pinout file in the top level source,
then re-compile ( The new pinout file will likely need to be added to the project )
What configuration do you need?
- slammers
02 Nov 2023 15:53 - 02 Nov 2023 15:56 #284341
by slammers
Replied by slammers on topic Creating custom configs for Mesa 7i80HDT
You use the Efinity software to do this? I have some experience with Verilog but not much with VHDL. I was hoping someone wrote something to get up and running quicker.
My immediate need is to configure this device to match the exact pinout of the 7i93. I have made my own customer interface board that uses two ribbon cables from the 7i93 to my board and since I can not get a 7i93, I was hoping it could use the 7i80HDT without modifying my hardware.
I have not got my LinuxCNC installation talking to the 7i80HDT yet so I am not sure if there is already a configuration that does this.
But I would like to have the ability to make my own configurations for a future project.
Last edit: 02 Nov 2023 15:56 by slammers.
02 Nov 2023 16:14 #284345
What 7I93 firmware are you using?
- slammers
02 Nov 2023 16:23 #284346
by slammers
I think it SVST4_4D_48
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=4 num_pwmgens=4 num_stepgens=4"
02 Nov 2023 19:15 #284362
This should have the same pinout (+ 4 more stepgens on the last connector)
Basically All I changed in the source was adding the pinout file
and adding it to the project and top level file.
You can edit the pin file to something you want and I can recompile
if you don't want to setup the tools
- slammers
02 Nov 2023 21:20 - 02 Nov 2023 21:25 #284377
by slammers
I updated my system to the master branch and now have
LINUXCNC - 2.10.0-pre0-2330-g292511db43
But when I run
mesaflash --addr 192.168.1.121 --device=ETHER --readhmid
I still get error
Unsupported ethernet device 7I80HDT at 192.168.1.121
No ETHER board found
Do I have to update the firmware on the device or should mesa flash recongnize it out of the box?
Also, when I run the Pncconf Wizard there is no choice for 7i80HDT, only the 7i80HD
But when I run
I still get error
Last edit: 02 Nov 2023 21:25 by slammers.
02 Nov 2023 21:31 #284378
You would need to update mesaflash to recognize the 7I80HDT
github.com/LinuxCNC/mesaflash
(build instructions at bottom of page)
Your older mesaflash version _should_ work for _reading_ with
the --device ether option so it may be there is a host configuration issue.
(what does "ip a" report?)
You do need to update mesaflash to correctly write to the 7I80HDT
- slammers
02 Nov 2023 22:44 #284388
by slammers
I would think if there was an issue with my ip config then it would not even detect that the attached ether device is a 7i80HDT. It finds the board but says its not supported.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether e8:6a:64:e9:68:f6 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.2/8 brd 192.255.255.255 scope global noprefixroute eno1
inet6 fe80::ea6a:64ff:fee9:68f6/64 scope link noprefixroute
02 Nov 2023 23:52 - 02 Nov 2023 23:53 #284400
I don't think that host configuration will work to access the card reliably
I would set the host IP address to 192.168.1.100/24 and disable IPV6
or better still 10.10.10.100/24 and set the 7I80HDT card to 10.10.10.10
(W2,W3 DOWN,UP and power cycle)
And then update mesaflash (since the old version of mesaflash cannot write
correctly to the 7I80HDT)
Last edit: 02 Nov 2023 23:53 by PCW.
Time to create page: 0.124 seconds
