7i96s and WJ200 VFD
- MachNegativeOne
03 Nov 2023 13:58 #284454
by MachNegativeOne
7i96s and WJ200 VFD was created by MachNegativeOne
Hi all,
I am wanting to hook up my 7i96s motion control board to my Hitachi WJ200 VFD using modbus. I have read the modbus page and have sees the WJ200 modbus driver - so all that seem good, it is just the protocol and the hardware connections. I have a couple of questions I could not find answers for by searching.
(1) The modbus page says "For RS422 Modbus RTU communications these should be connected at the Mesa card Tx+ to Rx+ and Tx- to Rx-". The WJ200 is RS485. I have read that RS485 bus components can be used with RS422 network, I just want to make sure this will work.
(2) The modbus pages says "Typically Rx+ and TX+ will connect to the B- pin on the modbus device and Rx- and Tx- will connect to the A+ pin" The WJ200 has SN and SP connections for RS485 (I presume this means serial neagative and serial positive). So does this mean: I connect the Rx+ and Tx+ together on the Mesa board and then connect that to the SN connection a=on the WJ200? (same for the Rx- and Tx- to SP)
If you have connected your Mesa motion control baord to the WJ200 using modbus, please let me know any other tips that may be useful.
thanks!
thanks!
- Thank you received: 5334
03 Nov 2023 14:52 #284459
Replied by PCW on topic 7i96s and WJ200 VFD
Yes I think you have polarity correct.
In addition on the 7I96S you need bias
resistors (100 to 300 Ohm)
from +5V to SP and GND to SN
The following user(s) said Thank You: MachNegativeOne
Time to create page: 0.073 seconds
