.bin for 7i92T + 7i77 + 7i37
- AMLD
04 Nov 2023 11:01 #284520
by AMLD
.bin for 7i92T + 7i77 + 7i37 was created by AMLD
Hello everyone, can someone help me with .bin file for 7I92TM with 7i77 on P2 connector and 7i37 on P1 conenctor?
I tried to generate .bin file with Efinity software versions 2023.1.150 and also 2021.2.323.6.17, but in both cases mesaflash stopped flashing with error: "wrong bitfile destination device: Trion, should be T20F256".
Project files are downloaded from official MESA website for 7I92T card.
I also rewrite value in .bin file, in row "Family" i change value from "Trion" to "T20F256". After that, flash was successful, but LEDs INIT and /DONE are still on. (I flash correct .bin file with IP adress jumper in UP/UP position)
What I am doing wrong?
Thank you.
Thank you.
- Thank you received: 5334
04 Nov 2023 15:33 - 04 Nov 2023 15:35 #284538
Replied by PCW on topic .bin for 7i92T + 7i77 + 7i37
Are you using the latest mesaflash?
You may have this issue if you have very long paths in your build environment.
This issue has been patched around back in mesafllash 3.4.x or so but even the
current version of mesaflash may not work for really long paths.
To get a hint of whats going on:
strings yourfirmware.bin | head -c 200
Last edit: 04 Nov 2023 15:35 by PCW.
The following user(s) said Thank You: AMLD
- AMLD
04 Nov 2023 16:38 #284544
by AMLD
Replied by AMLD on topic .bin for 7i92T + 7i77 + 7i37
Mesaflash version is 3.4.6
PCW, you are right.
After moving project to directory with short path, everything works well.
Thank you again.
PCW, you are right.
Thank you again.
04 Nov 2023 16:59 #284547
The latest mesaflash might also have worked with the longer paths
it was fixed in 3.4.9 (20 more chars worth)
