7i76e with 7i75
04 Nov 2023 22:41 #284575 by Keyepitts
7i76e with 7i75 was created by Keyepitts
Is there anything special required to add a 7i75 card to a 7i76e? I looked on Mesanet.com, but didn't find any firmware to download for this combination?
Running Linuxcnc 2.8
  • Moderator
  • Moderator
04 Nov 2023 23:30 #284582 by tommylight
Replied by tommylight on topic 7i76e with 7i75
No, just plug and go.
It is a break out board with good protection for the FPGA.
04 Nov 2023 23:47 #284583 by Keyepitts
Replied by Keyepitts on topic 7i76e with 7i75
Thanks for the quick reply TommyLight, I have it plugged in to P1, the led is lit on it, and I have 5v on the ground and supply pins. I ran halcmd, with the board attached and detached, and didn’t see any change in the available number of inputs. Any ideas why?
  • Moderator
  • Moderator
05 Nov 2023 01:08 #284587 by tommylight
In hal you use the normal GPIO pins, 7i75 should be transparent to FPGA.
What does mesaflash readhmid return ?
05 Nov 2023 02:04 #284589 by Keyepitts
I’ll have to check into mesaflash readhmid tomorrow morning, not sure if I have that installed on the computer. Thanks again for your help.
05 Nov 2023 03:11 #284592 by PCW
Replied by PCW on topic 7i76e with 7i75
If you install a recent version of mesaflash:
github.com/LinuxCNC/mesaflash
( build/install instructions on bottom of page )
You can get the GPIO -- 7I75 pinout:
mesaflash --device 7i76e --addr [card_ip_address] --dbname2 7i75 --readhmid
05 Nov 2023 15:14 #284633 by Keyepitts
I did have a version of mesaflash installed, but was unable to connect to the 7i75 board, the terminal didn’t like the —addr part, probably too old of a version of mesaflash, and my computer isn’t easily connected to the internet. But I was able to read the 7i76e board, which showed me the P1 and P2 pin addresses, which finally allowed me to figure out which gpio pins I was looking for, and I was able to locate them in halshow. On to the next challenge, thanks again everyone!
Moderators: PCW, jmelson
Time to create page: 0.279 seconds
