change p2 7i92t_5abobx2d.pin
- telmoram
11 Nov 2023 02:02 #285069
by telmoram
change p2 7i92t_5abobx2d.pin was created by telmoram
Hi, please can you help me changing the 7i92t_5abobx2d.pin firmware, I need only one encoder this in the P1 connector, and the P2 connector (P11, P12, P13) only as IOport for use inputs. Thanks.
- Thank you received: 5334
11 Nov 2023 02:10 #285070
Replied by PCW on topic change p2 7i92t_5abobx2d.pin
Encoder pins are available as GPIO inputs so no special firmware is
needed unless you want to use those pins as outputs.
- telmoram
11 Nov 2023 11:46 #285098
by telmoram
Replied by telmoram on topic change p2 7i92t_5abobx2d.pin
Thanks, I change the hal file and work.
Time to create page: 0.241 seconds
