7i90, 7c80, 7c81 support 32 spi bit word length
- Thank you received: 426
19 Nov 2023 00:22 #285872
7i90, 7c80, 7c81 support 32 spi bit word length was created by Cant do this anymore bye all
As per my experiments with 7i90 firmware & RPi-5, to use mesaflash I had to mod the code to allow only 8 bit word lengths for spi.
The same goes for the hm2_spi driver, only works when code is modded to use only 8 bit word lengths.
So far with hm2_rpspi I've had no luck getting this to work.
Any help or suggestions would be really helpful.
- Thank you received: 5334
19 Nov 2023 00:46 - 19 Nov 2023 01:08 #285873
Replied by PCW on topic 7i90, 7c80, 7c81 support 32 spi bit word length
I sounds like at the minimum mesaflash and hm2-spi should have a
command line option to force 8 bit SPI mode. I wonder if this is a
hardware limitation on the RPI5 or a kernel driver issue.
Edit: actually, it looks like mesaflash is supposed to automatically
fall back to 8 bit SPI mode if the probe fails. Are you saying that this fails?
Fixing hm2_rpspi would need low level hardware information on
RPI5's SPI interface.
Last edit: 19 Nov 2023 01:08 by PCW.
19 Nov 2023 02:21 - 19 Nov 2023 12:18 #285876
Replied by Cant do this anymore bye all on topic 7i90, 7c80, 7c81 support 32 spi bit word length
I think the RPi-5 does support 32 bit words (at least it reports it does), where as the RPi-3/4 doesn't.
What I'm thinking is the RPi-5 is reporting it supports 32 bit mode (probe is successful), either something is going wrong on the RPi-5 side or it's on the FPGA side.
The RPi-5 spi interface is on the RP1 chip, the new interface chip, which ATM only has draft info available.
Something I've noticed is that --write & --verify & --reload work fine without forcing 8 bit mode.
Last edit: 19 Nov 2023 12:18 by Cant do this anymore bye all.
19 Nov 2023 11:40 - 19 Nov 2023 12:17 #285887
Totally wrong.
Last edit: 19 Nov 2023 12:17 by Cant do this anymore bye all. Reason: wrong wrong wrong
Time to create page: 0.178 seconds
