DIY 7i90 and EPP
- Thank you received: 426
21 Nov 2023 02:03 #286137
DIY 7i90 and EPP was created by Cant do this anymore bye all
Thinking of this route, for the signals from the LPT port should I run them through a FET bus switch ? Any suggestion in the way of termination and such ?
Cheers
Rob
Cheers
Rob
- Thank you received: 5334
21 Nov 2023 14:31 #286176
Replied by PCW on topic DIY 7i90 and EPP
The 7I90 uses bus switches so the interface is 5V tolerant
but it may be that most existing parallel ports use 3.3V signaling
levels. A little poking around with a voltmeter would be useful.
Termination (impedance matching) is not needed as the transaction
rate is quite low and the parallel port is not capable of driving parallel
termination.
termination.
The following user(s) said Thank You: Cant do this anymore bye all
21 Nov 2023 17:07 #286183
Replied by Cant do this anymore bye all on topic DIY 7i90 and EPP
Once again thanks kind sir
Time to create page: 0.216 seconds
