Mesa 7i77 Analog Enable
- davew
10 Dec 2023 20:22 #287791
by davew
Replied by davew on topic Mesa 7i77 Analog Enable
I've attached the all.txt file and also the complete hal and ini files.
The loadrt line is:
# load low-level driver
loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](BOARD_IP) config=[HOSTMOT2](CONFIG)
setp hm2_[HOSTMOT2](BOARD).0.watchdog.timeout_ns 5000000
with the ini file parameters:
[HOSTMOT2]
DRIVER=hm2_eth
BOARD_IP=192.168.1.121
BOARD=7i92
CONFIG="sserial_port_0=110 sserial_port_1=00xxxx"
The loadrt line is:
[HOSTMOT2]
DRIVER=hm2_eth
BOARD=7i92
- Thank you received: 5334
10 Dec 2023 20:53 #287793
Replied by PCW on topic Mesa 7i77 Analog Enable
sserial_port_0=110
Will cause the analog section of the 7I77 to fault because
the analog section has no mode 1
- davew
10 Dec 2023 21:09 #287796
by davew
Thanks! That's it - the analog enable is working now.
So the CONFIG line should be:
CONFIG="sserial_port_0=100 sserial_port_1=00xxxx" which puts the 7i77 (port_0) in software mode 1 with four analog inputs.
Thanks Tommy and PCW for all your help - I would never have suspected that's where the problem lay.
10 Dec 2023 22:18 #287801
What GUI are you running? You should have got an error message,
something like:
hm2/hm2_7i92.0: Smart serial card hm2_7i92.0.7i77.0.1 remote error = (30) Illegal Remote Mode
something like:
- davew
10 Dec 2023 23:03 #287805
by davew
I'm using AXIS. I didn't see any obvious error message. Where would the message appear? It would be easy enough to set the config back to the faulty setting and confirm whether an error message crops up or not.
Time to create page: 0.095 seconds
