Mesa CT Huge Improvements Coming
2 years 9 months ago #290218 by JT
Replied by JT on topic Mesa CT Huge Improvements Coming
Some of the features of Mesa CT
*    Small 800 x 600 size for small monitors.
*    Create any type of configuration using any outputs
*    Fully editable ini file by the user, when loaded and saved custom sections and key value pairs and comments are not lost.
*    Firmware Flash, Reload, Verify Mesa cards
*    Read the config on the card as well as other card operations
*    Search for an Ethernet Mesa card using the common addresses that Mesa uses
*    Information about all the cards as well as the manuals for the cards, some
    cards have additional information.
*    Add MDI commands to the ini file
*    Add a Smart Serial card and configure the I/O
*    Add customs HAL commands
*    Change Motion, Debug, Thread Period Options, Digital and Analog I/O count
*    Add a VCP Panel
*    Add and configure the Classicladder PLC options
*    Get Motherboard, CPU, and NIC information about the PC
*    Test the Thread Period
*    Check the configuration for errors at any time during the creation
*    Load a configuration at startup
*    Create a backup of the entire configuration directory with a date and time stamp
*    Board layout image of all the daughter boards as well as the selected board
*    Wiring diagram for the Smart Serial connection
*    HAL function assistant to help create custom HAL code
*    Create additional HAL files
*    Add a README file
JT
The following user(s) said Thank You: tommylight, pommen, besriworld, Joco, jtrantow, spumco
2 years 3 months ago - 2 years 3 months ago #306377 by AirRacer
Replied by AirRacer on topic Mesa CT Huge Improvements Coming
I just installed mesact_2.1.5_amd64.deb over 2.1.4 but running it still shows 2.1.4-Build Date 7/16/2024 in the title bar. Any ideas? Synaptics package manager shows that v2.1.5 is installed.
Skylor
Last edit: 2 years 3 months ago by AirRacer.
2 years 3 months ago #306412 by AirRacer
I just realized that 7/16/2024 is probably the correct version date for 2.1.5 so it looks like the version number itself that’s displayed in the window title bar just wasn’t updated when 2.1.5 was created.
2 years 3 weeks ago #311461 by flyingbrick
Replied by flyingbrick on topic Mesa CT Huge Improvements Coming
Hi JT. Just wanted to say thank you for building this thing. As someone new to lcnc and with a 7i97t I was quite stuck before you added support :-)
2 years 2 weeks ago #312011 by flyingbrick
Hi JT. have found an issue with the CT.
using 7i97T. My first joint is fine but subsequent joints do not have the scale referenced correctly within hal txt file.
in the below snip I believe this should say Joint 1
Moderators: PCW, jmelson
Time to create page: 0.601 seconds
