Which Mesa Card Should I Buy?
- JackRay
- Thank you received: 14
20 Oct 2024 18:06 #312701
by JackRay
Replied by JackRay on topic Which Mesa Card Should I Buy?
hello everyone,I have just received my 7i96s board, the 5 axes work correctly with my RPI 4 . but I would like to work with an XYZBC trt configuration . The construction is easy with the configurations already proposed in stepconf . but I have no idea how to convert /establish the same configuration with Pncconf which is MESA oriented but without predefined configuration. Could someone please help me?Thank you
The following user(s) said Thank You: spumco, behai
- Thank you received: 5331
20 Oct 2024 22:47 #312715
Replied by PCW on topic Which Mesa Card Should I Buy?
The LinuxCNC parts (kins etc) of the configuration files of a Mesa or parallel
port setup would be basically identical. The per joint low level stepgen setup is
different but that the main change.
The following user(s) said Thank You: behai
- spumco
- Thank you received: 905
21 Oct 2024 03:13 #312717
by spumco
I'd prefer to keep this thread as specific as possible.
Replied by spumco on topic Which Mesa Card Should I Buy?
Please start a new topic for configuration troubleshooting and assistance.hello everyone,I have just received my 7i96s board, the 5 axes work correctly with my RPI 4 . but I would like to work with an XYZBC trt configuration . The construction is easy with the configurations already proposed in stepconf . but I have no idea how to convert /establish the same configuration with Pncconf which is MESA oriented but without predefined configuration. Could someone please help me?Thank you
- trilobyte
06 Nov 2024 09:44 #313883
by trilobyte
Replied by trilobyte on topic Which Mesa Card Should I Buy?
what about the availability? i haven't been active here for a long time. 2 years ago the 7i76e was not available, currently it is not available either. did it ever come back? or should i better use another card? i already have some 7i76s in use and would like to use the same hardware on all machines...
- Thank you received: 7488
06 Nov 2024 13:45 #313901
Replied by tommylight on topic Which Mesa Card Should I Buy?
Replied on the other topic in German, so here it is again:
Get a 7i96S, it has less IO, so if you need more get a 7i84 with 32 in and 16 out, can be usually found at www.eusurplus.com and easy to wire together with a cut LAN cable.
- trilobyte
11 Nov 2024 11:48 #314233
by trilobyte
i have one 7i76e in my stock, but will the 7i76e come back again? if so i can give my card to a friend. but i'll be able to buy another later to have one as a spare again
- my1987toyota
- Thank you received: 448
11 Nov 2024 12:56 #314236
by my1987toyota
Replied by my1987toyota on topic Which Mesa Card Should I Buy?
The 7i76E has been phased out. The 7i76EU is the replacement . Yes it is currently out of stock. However, I am sure
they will be back in stock soon. The first batches of them were available back in October and they seem to have
sold out quickly. Just keep checking the Mesa store.
store.mesanet.com/index.php?route=produc...83_85&product_id=399
The following user(s) said Thank You: trilobyte
- trilobyte
11 Nov 2024 14:51 #314247
by trilobyte
7i76EU would be fine too. ok, in this case i can wait and order if they are back in stock
- masawee
28 Jan 2026 12:23 #342075
by masawee
Replied by masawee on topic Which Mesa Card Should I Buy?
im newbie, and think need update my cnc machine whit mesa card, but true not understand and know what card need order, and totally not understand how flash firmware to card, if need flash. my old cnc machine has now only cheap paraller port BOB but problem is no have input pins, i want add my machine MPG pendant help lot whit work. what card i need order i not undrstand.
my cnc have 4 stepper motor dual Y axis, X,and Z,
input have now only XYZ home inductive sensor,
probe.
need add MPG hand wheel and switch,
one more stepper motor whit limit SW (4th axle to lathe on table addon)
cool flood output relay,
air cool relay,
maybe future some addons.
What card need buy ???
and were have download all speak lot this different bit files.
second project is buy cheap 7i92 mesa clone board aliexpress and need make plasma table.
how this add or flash bit file and were can download good bit file,
can 92 board use palsma X,Y,Z axis, THC what need doing ????
this need maybe 3 motors 6pin out,
THC i not know what need,
home SW 3 input,
output to plasma ?
what more need be?
probe.
air cool relay,
home SW 3 input,
output to plasma ?
what more need be?
28 Jan 2026 12:31 #342076
Mesa 7i96S is the best choice for Plasma.
I would really not advise using 7i92 for plasma unless you are very good at wiring and grounding and shielding.
Time to create page: 0.158 seconds
