Those are RPI issues, never ever Mesa issues.To be clear, I have a Raspberry Pi 5 and have been having ethernet stability issues when connecting to my 7i96s card. Thus during debugging I want to make sure I have the latest / most stable software versions installed.
Hi @tommylight,
Yeah i thought that was not the best answer as i understand why you are asking, but with Mesa there is no need to update firmware ever, changing firmware can be done based on your needs easily, i have a 7i92 and a 6i25 that i have flashed over 50 times doing all kinds of testing.
Also Mesa downloads will contain whatever firmware is available for that card, for some over 20 versions with different combos of stepgen/PWM/encoders/IO etc to choose from.
Just to be clear, i have no affiliation with Mesa, i used them once on a retrofit and got even specialised firmware from them in a day for exactly what i needed, from then on i exclusively use Mesa as they are extremely reliable, support is absolutely perfect as you can see above (PCW is the owner of Mesa), and by now i have over 80 Mesa boards on industrial machines in use daily, never had a single failure.
Yes, you are correct, it comes already flashed with the normal firmware for 5 step/dir and a spindle with encoder feedback, so no need to flash.
I am correct in understanding that when I get a new Mesa 7i96S card, I don't have to flash any firmware to it, please?
Hi @RNZ,Hi Behai. I purchased a couple of these cards from the US. I built a CNC around this card and a raspberry pi five. If you want to chat about it, I’m at the top of the South Island.
