7I96 Encoder Spindle tuning
2 years 7 months ago #295065 by PCW
Replied by PCW on topic 7I96 Encoder Spindle tuning
SPINX1
+6V to SPINX1 SPIN+
6V common to SPINX1 SPIN- and KBEC P1
SPINX1 SPINOUT to KBEC P2
Isolation is key, make sure there in no connection
between the 6V supply and ground (with an ohmmeter)
2 years 7 months ago #295141 by kbec
Replied by kbec on topic 7I96 Encoder Spindle tuning
So you are saying to rewire as in the attached diagram? The incoming port on the SPINX1 labels that as +5v. Would 1 V make that much of a difference?
I assume you are referring to this:
"The output of the control is a linear function of potentiometer rotation. The KBIC® can also be operated in a voltage following mode by supplying an isolated analog signal (0-7 VDC) to the input terminals P2 (+) and F-."
If that is the case, should I use +7 V or is that too much?, and I need to connect SP- to F -?.
2 years 7 months ago #295142 by PCW
No, the 6V supply connects to SP+ and SP-
+6V --> SP+
-6V  --> SP- and P1
SPV --> P2
Nothing on the 5V 7I96 side should connect to the spindle drive
2 years 7 months ago #295143 by kbec
I think I understand, I thought the SPINX1 had those as output, so I need to hook up power there. as well.
Like this:
2 years 7 months ago #295144 by PCW
SPV (the variable 0 to +6V voltage) goes to P2
2 years 7 months ago #295146 by kbec
You mean like this:
Moderators: PCW, jmelson
Time to create page: 0.238 seconds
