If pin 13 is damaged on the 5I25 it would prevent the last 7I74
channel from working (though it may still work as it's the TXEN
line and if its stuck low, the sserial channel will still work)
Typically if 5I25 inputs are damaged, it means they have been
exposed to negative currents >50 mA. This will usually short
out the clamp diode on the bus switch, leading to a stuck low pin.
This can happen if you plug in the DB25 cable and this connection
joins two systems with different ground domains (say a machine tool and a PC)
This also why Pin 13 and pin 1 are common victims (they are often the first to connect)
