Mesa 7i71 - Stepgen on Digital Output for ATC
- Thank you received: 5308
28 May 2024 17:30 #301690
Replied by PCW on topic Mesa 7i71 - Stepgen on Digital Output for ATC
Do you have the 7I52S TXEN0 set low?
A 50 pin FPGA card option would be a 6I24 (PCIE) or 7I80HDT (Ethernet)
- hardware_crash
28 May 2024 17:46 - 28 May 2024 17:47 #301693
by hardware_crash
Replied by hardware_crash on topic Mesa 7i71 - Stepgen on Digital Output for ATC
I read about it in the 7i52S manual, but wasn't sure how to do it.
Like so ?
I also tried the second Port COMM1 which shouldn't need that setting, right?
That one also didnt produce output to the stepper driver
Thanks for the info about those two boards, so theres no future proof board for the external pcie cable connection.
Like so ?
setp gpio.XX.is_output true
setp gpio.XX.out falseI also tried the second Port COMM1 which shouldn't need that setting, right?
Last edit: 28 May 2024 17:47 by hardware_crash.
28 May 2024 18:52 - 28 May 2024 19:10 #301701
Possible reasons for no steps:
Too short step length settings
Wrong FPGA connector
Wrong firmware
No 5V to 7I52S
To check the hardware, you can setup the stepgens to generate slow squarewaves:
(rename to pcistepgens and chmod +x pcistepgens)
This allows the step and dir outputs to be check with just a LED+resistor
Note the this script needs the latest mesaflash:
github.com/LinuxCNC/mesaflash
and it's run with:
sudo pcistepgens 4i65
Wrong firmware
No 5V to 7I52S
and it's run with:
Last edit: 28 May 2024 19:10 by PCW.
- hardware_crash
01 Jun 2024 18:26 #302086
by hardware_crash
Dear Peter,
I tested with your script and can confirm (with oscilloscope), that there is a very slow square wave output on the step pins, the motor also seems to be driven.
So where to go from here ?
Thanks, Lukas
Thanks, Lukas
01 Jun 2024 18:29 #302088
You might try huge step times (say 10000 ns) in your
LinuxCNC configuration since it look like the hardware is OK
- hardware_crash
01 Jun 2024 20:22 - 01 Jun 2024 20:28 #302102
by hardware_crash
I can seem to get it to work
Heres what I have in my INI File:
And in the HAL File:
When I press the jog button for that axis, I get movement on the stepper motor but just one step regardless of how long i push the jog button. When I release the button the motor makes a step, but it should continuously move ..
# A Axis
[AXIS_A]
MIN_LIMIT = -9999.0
MAX_LIMIT = 9999.0
MAX_VELOCITY = 360.0
MAX_ACCELERATION = 1200.0
[JOINT_3]
TYPE = ANGULAR
MIN_LIMIT = -9999.0
MAX_LIMIT = 9999.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
BACKLASH = 0.003
HOME = 0.000
HOME_OFFSET = 1.0
HOME_SEARCH_VEL = 3.0
HOME_LATCH_VEL = 0.2
HOME_SEQUENCE = 0
HOME_IS_SHARED = 1
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 80.0And in the HAL File:
# A Axis
setp pid.a.Pgain [JOINT_3]P
setp pid.a.Igain [JOINT_3]I
setp pid.a.Dgain [JOINT_3]D
setp pid.a.bias [JOINT_3]BIAS
setp pid.a.FF0 [JOINT_3]FF0
setp pid.a.FF1 [JOINT_3]FF1
setp pid.a.FF2 [JOINT_3]FF2
setp pid.a.deadband [JOINT_3]DEADBAND
setp pid.a.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.a.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.a.maxerror 0.82700
net a-index-enable => pid.a.index-enable
net a-enable => pid.a.enable
net a-pos-cmd => pid.a.command
net a-pos-fb => pid.a.feedback
net a-output <= pid.a.output
# Schritt-Gen Signale/Setup
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirsetup [JOINT_3]DIRSETUP
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.dirhold [JOINT_3]DIRHOLD
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.steplen [JOINT_3]STEPLEN
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.stepspace [JOINT_3]STEPSPACE
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-scale [JOINT_3]STEP_SCALE
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.step_type 0
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.control-type 1
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_[HOSTMOT2](BOARD).0.stepgen.01.maxvel [JOINT_3]STEPGEN_MAXVEL
# ---Closed-Loop Schrittmotor-Signale---
net a-pos-cmd <= joint.3.motor-pos-cmd
net a-vel-cmd <= joint.3.vel-cmd
net a-output => hm2_[HOSTMOT2](BOARD).0.stepgen.01.velocity-cmd
net a-pos-fb <= hm2_[HOSTMOT2](BOARD).0.stepgen.01.position-fb
net a-pos-fb => joint.3.motor-pos-fb
net a-enable <= joint.3.amp-enable-out
net a-enable => hm2_[HOSTMOT2](BOARD).0.stepgen.01.enableWhen I press the jog button for that axis, I get movement on the stepper motor but just one step regardless of how long i push the jog button. When I release the button the motor makes a step, but it should continuously move ..
Last edit: 01 Jun 2024 20:28 by hardware_crash.
- Thank you received: 7462
01 Jun 2024 20:55 #302107
Replied by tommylight on topic Mesa 7i71 - Stepgen on Digital Output for ATC
That points to having step and dir pins to drive reversed, try rewiring them.When I press the jog button for that axis, I get movement on the stepper motor but just one step regardless of how long i push the jog button. When I release the button the motor makes a step, but it should continuously move ..
- hardware_crash
01 Jun 2024 21:10 #302108
by hardware_crash
Thats what I thought too, but with Peters script and a rate=0x40000 in that script, the motor is moving correct...
01 Jun 2024 21:13 #302109
The script uses quadrature mode so puts out "step" pulses on both pins
