inmux mesa card 7i90
2 years 6 months ago #298499 by telmoram
Replied by telmoram on topic inmux mesa card 7i90
Ok, please.
2 years 6 months ago #298500 by PCW
Replied by PCW on topic inmux mesa card 7i90
File Name: 7i90_epp_s...nmux.zip
File Size:88.73 KB
inmux moved from 0x81xx..0x84xx to 0x70xx..74xx so should work with EPP
2 years 6 months ago #298505 by telmoram
ok, i am test and the inmux with length its only 1, start linuxcnc show message inmux 0 scanrate to low, and the only input enabled read the data input.
2 years 6 months ago #298507 by PCW
What does mesaflash [xxxxxxxx] --readhmid report?
2 years 6 months ago #298509 by telmoram
this message
Configuration Name: HOSTMOT2
  BoardName : MESA7I90
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 24
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: InMux
  There are 1 of InMux in configuration
  Version: 0
  Registers: 5
  BaseAddress: 7000
  Module: MuxedQCount
  There are 6 of MuxedQCount in configuration
  Version: 4
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: PWM
  There are 6 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       PWM              0        /Enable         (Out)
 3                      1   IOPort       MuxedQCount      0        MuxQ-A          (In)
 5                      2   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7                      3   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 9                      4   IOPort       MuxedQCount      1        MuxQ-A          (In)
11                      5   IOPort       MuxedQCount      1        MuxQ-B          (In)
13                      6   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
15                      7   IOPort       MuxedQCount      2        MuxQ-A          (In)
17                      8   IOPort       MuxedQCount      2        MuxQ-B          (In)
19                      9   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
21                     10   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
23                     11   IOPort       PWM              0        PWM             (Out)
25                     12   IOPort       PWM              0        Dir             (Out)
27                     13   IOPort       PWM              1        PWM             (Out)
29                     14   IOPort       PWM              1        Dir             (Out)
31                     15   IOPort       PWM              2        PWM             (Out)
33                     16   IOPort       PWM              2        Dir             (Out)
35                     17   IOPort       PWM              3        PWM             (Out)
37                     18   IOPort       PWM              3        Dir             (Out)
39                     19   IOPort       PWM              4        PWM             (Out)
41                     20   IOPort       PWM              4        Dir             (Out)
43                     21   IOPort       PWM              5        PWM             (Out)
45                     22   IOPort       PWM              5        Dir             (Out)
47                     23   IOPort       PWM              0        /Enable         (Out)
IO Connections for P2
 1                     24   IOPort       InMux            0        Addr0           (Out)
 3                     25   IOPort       InMux            0        Addr1           (Out)
 5                     26   IOPort       InMux            0        Addr2           (Out)
 7                     27   IOPort       InMux            0        Addr3           (Out)
 9                     28   IOPort       InMux            0        Data0           (In)
11                     29   IOPort       None
13                     30   IOPort       None
15                     31   IOPort       None
17                     32   IOPort       None
19                     33   IOPort       None
21                     34   IOPort       None
23                     35   IOPort       None
25                     36   IOPort       None
27                     37   IOPort       None
29                     38   IOPort       None
31                     39   IOPort       None
33                     40   IOPort       None
35                     41   IOPort       None
37                     42   IOPort       None
39                     43   IOPort       None
41                     44   IOPort       None
43                     45   IOPort       None
45                     46   IOPort       None
47                     47   IOPort       None
IO Connections for P3
 1                     48   IOPort       None
 3                     49   IOPort       None
 5                     50   IOPort       None
 7                     51   IOPort       None
 9                     52   IOPort       None
11                     53   IOPort       None
13                     54   IOPort       None
15                     55   IOPort       None
17                     56   IOPort       None
19                     57   IOPort       None
21                     58   IOPort       None
23                     59   IOPort       None
25                     60   IOPort       None
27                     61   IOPort       None
29                     62   IOPort       None
31                     63   IOPort       None
33                     64   IOPort       None
35                     65   IOPort       None
37                     66   IOPort       None
39                     67   IOPort       None
41                     68   IOPort       None
43                     69   IOPort       None
45                     70   IOPort       None
47                     71   IOPort       None
2 years 6 months ago #298510 by PCW
Oops got to find another address maybe tommorow
The following user(s) said Thank You: telmoram
Moderators: PCW, jmelson
Time to create page: 0.339 seconds
