Mesa Analog Vs Step Dir
- anfänger
- Thank you received: 267
16 May 2024 19:42 - 16 May 2024 19:43 #300778
by anfänger
Replied by anfänger on topic Mesa Analog Vs Step Dir
@PCW may I ask if is there a ready to use bitfile for the 7i97 and 7i85s I just found some of the 7i85 and the Firmware download on the page 7i85s doesn't work for me.
Many thanks
Many thanks
Last edit: 16 May 2024 19:43 by anfänger.
- Thank you received: 5334
16 May 2024 19:45 #300779
Replied by PCW on topic Mesa Analog Vs Step Dir
You have a 7I97, not a 7I97T?
- anfänger
16 May 2024 19:52 - 16 May 2024 19:53 #300780
by anfänger
I checks my order and should have a 7I97 Ethernet interfaced Analog servo plus I/O and a 7IA0 Isolated remote I/O card running in this machine right now. At least according to my order from back then.
Last edit: 16 May 2024 19:53 by anfänger.
16 May 2024 19:59 - 16 May 2024 20:00 #300781
OK I'll make 7I97/7I85S firmware
Did this need any other features?
Last edit: 16 May 2024 20:00 by PCW.
- anfänger
16 May 2024 20:07 - 16 May 2024 20:08 #300782
by anfänger
No the rest should be pretty stock, just need to know how the step Dir ist setup to configure the drivers.
is if there is one pin step+ and one step-
or one pin step and the other direction.
again thanks for your kind support
Last edit: 16 May 2024 20:08 by anfänger.
16 May 2024 21:33 #300784
Firmware for a 7I97 + 7I85S
Note that a full configuration will not fit so I dropped 1 stepgen.
(so only 3 step/dir channels) I could drop encoders (out of the 10 total)
if that's a better fit
The 7I85S has differential stepgen outputs so you have STEP+,STEP-,DIR+,DIR-
If you only need single ended outputs, you just leave the unused outputs unconnected.
- anfänger
17 May 2024 05:27 - 17 May 2024 05:35 #300800
by anfänger
Many thanks, I would need all four Stepgen ( single ended) I don’t need all encoders, eight would be the max. If I want to read the servo and axis encoders.
I could also Not use one of the pwm channels.
Just out of curiosity can the stepgen outputs be setup so step+/- is a step in cw and dir+/- a step in ccw
my drivers can handle both it’s just to know for future projects
Last edit: 17 May 2024 05:35 by anfänger.
- besriworld
- Thank you received: 92
17 May 2024 05:54 #300803
by besriworld
Replied by besriworld on topic Mesa Analog Vs Step Dir
linuxcnc.org/docs/html/man/man9/hostmot2.9.html#stepgen
Yes, it can. Maybe it makes more sense in quadrature mode? And I'm interested in what PCW thinks.
17 May 2024 15:02 #300835
Yes, CW/CCW mode is available though in general I would prefer Quadrature
if the drives support it (square wave outputs so no timing setup basically)
7I97 + 7I85S 4 stepgens but only 2 encoders (6,7) on 7I85S
The following user(s) said Thank You: besriworld, anfänger
- anfänger
17 May 2024 16:20 #300840
by anfänger
The drivers actually support that, so they can be driven by a hand wheel.
Many thanks again. With some luck the card will be here tomorrow.
Time to create page: 0.335 seconds
