7i96s + 7i89 questions
- JohnnyBeluga
20 May 2024 19:24 #301027
by JohnnyBeluga
7i96s + 7i89 questions was created by JohnnyBeluga
Hi !
I had a 7i96s when i started the conversion of my mini mill. As I planned to add linear scales for feedback I bought a 7i89 daugther card. I already used the 7i96s in various project with success. But in pcconf when I select the 7i96s as card0 I can't see 7i89 in options for card1. Do I need a custom firmware ? Should I contact mesa ? Can I do the conf for the 7i96s in pcconf and add manually the 7i89 ?
- Thank you received: 5334
20 May 2024 21:13 #301034
Replied by PCW on topic 7i96s + 7i89 questions
You may be able to use pncconfs discovery option to allow setting up
the additional encoders.
You do need to use 7I96S firmware that supports the 7I89, that would be:
7i96s_7i89d.bin
7i96s_7i89d.bin
- JohnnyBeluga
23 May 2024 17:30 - 23 May 2024 17:32 #301234
by JohnnyBeluga
Replied by JohnnyBeluga on topic 7i96s + 7i89 questions
Thank you. Shame on me, I thought I had to make the firmware myself. After a day of struggle I found it on mesa store 7i96s page specification -> software. So I just need to flash and try to proceed with pncconf ? HostMot2 is to modify a mesa card firmware and Xilinx studio to create one from scratch for any xilinx card including mesa ones ?
Last edit: 23 May 2024 17:32 by JohnnyBeluga.
23 May 2024 17:47 #301236
Yes, you flash the firmware with mesaflash (make sure you have a recent copy)
pncconf's discovery option will be needed to make the new firmwares encoders
visible.
The source code is there if you want to build you own configurations. Note the the 7I96S uses
an Efinix FPGA chip so needs the Efinity tool chain, not a Xilinx tool chain.
visible.
- JohnnyBeluga
24 May 2024 18:33 - 24 May 2024 18:37 #301345
by JohnnyBeluga
I followed this guide for discovery option. forum.linuxcnc.org/39-pncconf/52554-disc...n-unlisted-mesa-fpga
on readhmid I have:
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
There are 10 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: OutM
There are 1 of OutM in configuration
Version: 0
Registers: 1
BaseAddress: B000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InM
There are 1 of InM in configuration
Version: 0
Registers: 5
BaseAddress: 8500
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I89
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-1,2,9,10 0 IOPort InM 0 Input0 (In)
TB3-4,5,12,13 1 IOPort InM 0 Input1 (In)
TB2-7,8,15,16 2 IOPort InM 0 Input2 (In)
TB3-17,18,TB2-1,2 3 IOPort InM 0 Input3 (In)
TB3-20,21,TB2-4,5 4 IOPort InM 0 Input4 (In)
TB3-23,24,TB2-7,8 5 IOPort InM 0 Input5 (In)
TB2-9,10,17,18 6 IOPort InM 0 Input6 (In)
TB2-12,13,20,21 7 IOPort InM 0 Input7 (In)
TB2-15,16,23,24 8 IOPort InM 0 Input8 (In)
TB1-1,2,9,10 9 IOPort InM 0 Input9 (In)
TB1-4,5,12,13 10 IOPort InM 0 Input10 (In)
TB1-7,8,15,16 11 IOPort SSR 0 Out-00 (Out)
Internal-EncMux 12 IOPort SSR 0 Out-01 (Out)
Internal-EncPower 13 IOPort SSR 0 Out-02 (Out)
TB1-19,20 14 IOPort SSR 0 Out-03 (Out)
TB1-21,22 15 IOPort OutM 0 Output4 (Out)
Internal-TXEn 16 IOPort OutM 0 Output5 (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3 17 IOPort StepGen 0 Step/Table1 (Out)
TB1-4,5 18 IOPort StepGen 0 Dir/Table2 (Out)
TB1-8,9 19 IOPort StepGen 1 Step/Table1 (Out)
TB1-10,11 20 IOPort StepGen 1 Dir/Table2 (Out)
TB1-14,15 21 IOPort StepGen 2 Step/Table1 (Out)
TB1-16,17 22 IOPort StepGen 2 Dir/Table2 (Out)
TB1-20,21 23 IOPort StepGen 3 Step/Table1 (Out)
TB1-22,23 24 IOPort StepGen 3 Dir/Table2 (Out)
TB2-2,3 25 IOPort StepGen 4 Step/Table1 (Out)
TB2-4,5 26 IOPort StepGen 4 Dir/Table2 (Out)
TB2-7,8 27 IOPort MuxedQCount 4 MuxQ-A (In)
TB2-10,11 28 IOPort MuxedQCount 4 MuxQ-B (In)
TB2-13,14 29 IOPort MuxedQCount 4 MuxQ-IDX (In)
TB2-16,17 30 IOPort SSerial 0 RXData0 (In)
TB2-18,19 31 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 32 IOPort SSerial 0 TXEn0 (Out)
Internal 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01 34 IOPort MuxedQCount 0 MuxQ-A (In)
P1-02/DB25-14 35 IOPort MuxedQCount 0 MuxQ-B (In)
P1-03/DB25-02 36 IOPort MuxedQCount 0 MuxQ-IDX (In)
P1-04/DB25-15 37 IOPort MuxedQCount 1 MuxQ-A (In)
P1-05/DB25-03 38 IOPort MuxedQCount 1 MuxQ-B (In)
P1-06/DB25-16 39 IOPort MuxedQCount 1 MuxQ-IDX (In)
P1-07/DB25-04 40 IOPort MuxedQCount 2 MuxQ-A (In)
P1-08/DB25-17 41 IOPort MuxedQCount 2 MuxQ-B (In)
P1-09/DB25-05 42 IOPort MuxedQCount 2 MuxQ-IDX (In)
P1-11/DB25-06 43 IOPort MuxedQCount 3 MuxQ-A (In)
P1-13/DB25-07 44 IOPort MuxedQCount 3 MuxQ-B (In)
P1-15/DB25-08 45 IOPort MuxedQCount 3 MuxQ-IDX (In)
P1-17/DB25-09 46 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P1-19/DB25-10 47 IOPort None
P1-21/DB25-11 48 IOPort SSerial 0 RXData1 (In)
P1-23/DB25-12 49 IOPort SSerial 0 TXData1 (Out)
P1-25/DB25-13 50 IOPort SSerial 0 TXEn1 (Out)
is this normal :
that should be 7i89 on p1 I think. The discovery option worked and, in pncconf, 7i89 inputs is at P1. I just had some pain to found the input tab of the Help window to paste the 7i96s_7i89d.pin file content. And the channel numbers are a little bit messed up inside each tab. Is there a chance of damaging a pin if there is a mistake in the file made with pncconf ? I will check in the hal file
on readhmid I have:
FPGA Pins: 256
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: OutM
Version: 0
Registers: 1
BaseAddress: B000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: SSR
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InM
Version: 0
Registers: 5
BaseAddress: 8500
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
is this normal :
Last edit: 24 May 2024 18:37 by JohnnyBeluga.
24 May 2024 18:44 #301347
It looks like you used the wrong dbname in the mesaflash command line.
is should be something like:
mesaflash --device 7i96s --addr 10.10.10.10 --dbname3 7i89 --readhmid
Pncconf cannot do anything harmful
Using the wrong firmware that does not match the daughtercard can theoretically cause
damage (excessive current from conflicting outputs) but I have never seen this happen
- JohnnyBeluga
25 May 2024 18:04 #301425
by JohnnyBeluga
Thank you; as always I should have read better the manual "Daughtercard specific pinouts can be specified by adding dbname3 cardname to
mesaflash’s readhmid command:" Can I ask you why it's named db3 as there is only one header ?
25 May 2024 20:55 #301442
The db number is related to the port (a 7I96 has 3 ports and the expansion port is the last)
Mesaflash probably should complain about db numbers for on-card ports.
Time to create page: 0.137 seconds
