MesaTool2, 7i96S and BOB (HW-356)
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
29 May 2024 23:35 #301784 by Project_Hopeless
MesaTool2, 7i96S and BOB (HW-356) was created by Project_Hopeless
I have firmware for a 7i96S+BOB setup.
PIN_7I96S_5ABOBRCD.vhd
With this firmware and MesaTool2 do I  select a P1 board type?  I don't see anything resembling a generic BOB.
30 May 2024 01:06 - 30 May 2024 01:48 #301788 by jimmyrig
Replied by jimmyrig on topic MesaTool2, 7i96S and BOB (HW-356)
Edit..... Nevermind can do this from mesact
I​​d you are trying to use a 7i96s with a bob you need to install the firmware first.
Go to the mesa website, your board, download the firmware files
The in console,
Sudo install mesflash (edited.. Thanks)
The see all the commands with mesaflash --help
If memory serves
Cd to your firmware
The the command is something like
Mesact flash -- ipaddr, --board, --firmware file
That'll get you the firmware flashed.
The use the hostmod command to see what pins you can call from hal file
Last edit: 30 May 2024 01:48 by jimmyrig.
  • Moderator
  • Moderator
30 May 2024 01:41 #301794 by tommylight
Replied by tommylight on topic MesaTool2, 7i96S and BOB (HW-356)
Do you mean mesaflash ?
MesaCT can flash the firmware from the GUI.
The following user(s) said Thank You: jimmyrig
30 May 2024 03:46 #301810 by PCW
Replied by PCW on topic MesaTool2, 7i96S and BOB (HW-356)
Also note, 7I96S firmware files end in .bin
PIN_7I96S_5ABOBRCD.vhd is a source file,
not a complete firmware file
  • Project_Hopeless
  • Elite Member
  • Elite Member
30 May 2024 22:48 #301895 by Project_Hopeless
Replied by Project_Hopeless on topic MesaTool2, 7i96S and BOB (HW-356)
tommylight post=301794 userid=17274Do you mean mesaflash ?
Yes MesaCT (Mesa Configuration Tool).  I have the *.pin, *.bin, and *.vhd files for the7i96s_5abobrcd firmware.
So after flashing the 7i96S and connecting the BOB.  Will MesaCT recognize the BOB being connected?  Do I then need to assign the BOB to the P1 connector?
31 May 2024 05:38 #301925 by jimmyrig
I'm not familiar with that software but yes set your pins in the p1 connector like it was the breakout board connecting to a parallel port.
E.g. step and direction for axis x on the bob is usually pins 2,3 on the parallel port (and the p1)
Hope that helps
31 May 2024 14:44 #301957 by JT
Replied by JT on topic MesaTool2, 7i96S and BOB (HW-356)
No MesaCT does not know what you have connected. And not all combinations of cards has been programed at this time.
JT
Moderators: PCW, jmelson
Time to create page: 0.608 seconds
