- Hardware & Machines
- Driver Boards
- Error in 7i96s firmware update file to connect with 7i77 result Checking file...
- programador
- Thank you received: 5
30 May 2024 01:20 #301789
by programador
Error in 7i96s firmware update file to connect with 7i77 result Checking file... was created by programador
Hello everyone, please, I need help updating the firmware of the 7i96s board to recognize the P1 host connection with 7i77. I'm a beginner and I may be making some basic mistake. Please any tips help.
Below is the update command:
cnc@cnc:~/Documentos/7i96s/configs/hostmot2$ sudo mesaflash --device 7i96s --addr 10.10.10.10 --write 7i96s_7i77d.bin --reload
result:
Checking file... Invalid bitfile header!
The directory is www.mesanet.com/software/parallel/7i96s.zip
Below is the type of board version I'm using:
cnc@cnc:~/Documentos/7i96s/configs/hostmot2$ sudo mesaflash --device 7i96s --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName: MESA7I96
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 160.0000 MHz
IDROM Type: 3
Instance Stride 0:4
Instance Stride 1:64
Register Stride 0:256
Register Stride 1: 256
result:
BoardName: MESA7I96
FPGA Pins: 256
IDROM Type: 3
Instance Stride 0:4
- Thank you received: 7490
30 May 2024 01:39 #301792
Replied by tommylight on topic Error in 7i96s firmware update file to connect with 7i77 result Checking file...
Do you have a 7i96 or 7i96S ? Those are not the same firmware wise although functionally they are pretty much the same.
The following user(s) said Thank You: programador
- programador
30 May 2024 02:25 #301801
by programador
Replied by programador on topic Error in 7i96s firmware update file to connect with 7i77 result Checking file...
Yes, The electronic board says 7i96s. When purchasing, the 7i96s was chosen. The board layout is from 7i96s.
Is there any jumper or configuration to enable the card update, perhaps some necessary operating system permission procedure? I'm using LinuxCNC 2.8.4
- Thank you received: 5334
30 May 2024 03:10 #301809
Replied by PCW on topic Error in 7i96s firmware update file to connect with 7i77 result Checking file...
You need an up-to-date version of mesaflash
github.com/LinuxCNC/mesaflash
(Build instructions at bottom of page)
- programador
30 May 2024 21:01 #301888
by programador
Thank you very much. When upgrading the system from LinuxCNC 2.8.4 to LinuxCNC 2.9.2, I got the newest version of the MesaFlash software which was 3.4.0 and now it is 3.4.9 on this new system. With this I was able to update the firmware successfully. But unfortunately I have not yet been successful in recognizing the 7i77 board in the LinuxCNC system. I'm using the LinuxCNC Pncconf Wizard, and the ports on the 7i77 board don't appear in place of the P1 connector, they don't appear in the configuration settings, please, is there any other procedure for the board to be recognized?Pncconf does not appear 7i77
Halshow does not appear 7i77
- programador
30 May 2024 21:07 - 30 May 2024 21:10 #301889
by programador
below the update carried out successfully! but without recognition of the 7i77 board even after restarting the system and electricity
Checking file... OK
File type: Efinix bin file
FLASH memory sectors to write: 11, max sectors in area: 16
Erasing FLASH memory sectors starting from 0x100000...
|EEEEEEEEEEE
Programming FLASH memory sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
Verifying FLASH memory sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board FLASH memory verified successfully.
Checking file... OK
|EEEEEEEEEEE
Checking file... OK
Last edit: 30 May 2024 21:10 by programador.
30 May 2024 21:13 #301890
The 7I77 will not appear in halshow until you:
1. Have the 7I77 connected to the 7I96S P1 connector with the proper cable
2. Have 5V power applied properly to the 7I77 (and the 7I96S P1 power option matches the 7I77 5V option)
3. Have field power applied to the 7I77 (and 7I77 W1 Left)
I don't think pncconf knows how to make a 7I96S+7I77 configuration so you may need to merge
a plain 7I96S configuration with say a 7I92+7I77 configuration (for the analog/encoder/7I77 I/O setup)
- programador
30 May 2024 23:03 #301896
by programador
- Driver Boards
Time to create page: 0.103 seconds
