Tandem Stepper Motors
- Project_Hopeless
- Thank you received: 10
31 May 2024 21:39 #302006
by Project_Hopeless
Tandem Stepper Motors was created by Project_Hopeless
I have a project with two stepper motors driving a single axis. The motors are connected to the axis hub with T5 16mm belts. So they should almost never fall out of step with each other.
The robot is 5-DOF but has six motors and I would like to keep all the steppers on the Mesa card. With a Mesa 7i96S can I drive two stepper drivers, in parralell, from a single step/gen output?
- Thank you received: 5326
31 May 2024 21:51 #302008
Replied by PCW on topic Tandem Stepper Motors
Normally, yes.
If the drives have PUL+ and PUL- you can
wire the outputs (assuming channel 4):
Drive 1
PUL+ --> 7I96S STEP4+
PUL- --> 7I96S GND
DIR+ --> 7I96S DIR4+
DIR- --> 7I96S GND
Drive 2
PUL+ --> 7I96S +5V
PUL- --> 7I96S STEP4-
DIR+ --> 7I96S +5V
DIR- --> 7I96S DIR4-
So you do not double the loading
on the 7I96S step/dir outputs
Drive 1
PUL- --> 7I96S GND
DIR- --> 7I96S GND
Drive 2
PUL+ --> 7I96S +5V
DIR+ --> 7I96S +5V
The following user(s) said Thank You: Project_Hopeless
