error finishing read!
- Anton
- Thank you received: 5
01 Jun 2024 09:08 #302058
by Anton
error finishing read! was created by Anton
Hello, I'm new to this forum and this is my first post. After a quick read and some YouTube videos, I installed the latest LinuxCNC ISO (2.9.2) and created a first configuration with the PnCconf. The connection (ping) to the 7i96s works. I was able to read inputs. I connected a JMC closed loop motor (step/dir and supply voltage). The settings for the motor also seem to be correct, it turns once when I let the machine move 5mm. Unfortunately, this error then appears quite soon:
hm2/hm2_7i96s.0: error finishing read! iter =....
The INIT diode on the mesa card then lights up red and LinuxCNC has to be restarted.
Sometimes this error also occurs:
motor 0 position error
Another strange behaviour occurs after moving one step (5mm, 1mm, ... ), the controller always switches off and I have to press the switch-on button in LinuxCNC again so that the controller is on again and I can move the axes for a short time.
best regards Anton
best regards Anton
- Thank you received: 5337
01 Jun 2024 10:10 - 01 Jun 2024 10:11 #302064
Replied by PCW on topic error finishing read!
This is most likely a latency issue
1. have you run a latency test?
I would suggest "latency-histogram --nobase --sbinsize 1000"
2. Have you disabled all power management options in the BIOS setup?
This include turbo modes, EIST, Cstates > C1, Cool&Quiet etc, basically
anything that causes the CPU to change speeds dynamically or sleep.
3. Also in the BIOS you should disable hyperthreading and any management
engine related options that affect the network (like AMT)
4. If your PC has an Intel Ethernet chip make sure you disable IRQ coalescing
(man hm2_eth)
5. Pinging the 7I96S will give you some idea of network latency
(this example assumes the 7I96S is set for a 10.10.10.10 IP address)
ping -i .2 -c 4 10.10.10.10
sudo chrt 99 ping -i .001 -q 10.10.10.10
(let the last command run for a few minutes and
then stop it with a control C, it will print timing statistics)
If BIOS changes and disabling IRQ coalescing do not help, the next step is to try
changing the kernel command line options, using isolcpus to isolate one processor
for real time use and pinning the Ethernet IRQ to that processor.
(man hm2_eth)
Last edit: 01 Jun 2024 10:11 by PCW.
- Anton
01 Jun 2024 12:53 #302079
by Anton
Replied by Anton on topic error finishing read!
Thank you very much for the quick reply.
Regarding 1) I looked at the jitter in the latency test and it was in the very good range. I am using a laptop (i7), could this be an additional problem? In Linux I switched off everything that could be switched off there via power options. I have not yet made any settings in the bios.
I will go through points 2 to 5 tomorrow.
I only have basic knowledge of Linux so far and, as already mentioned, I am an absolute beginner in the field of Linux cnc. If steps 1-5 don't bring any improvement on my laptop, I would contact you again about the kernel swap, I don't know how to do that now.
Best regards from Marburg
01 Jun 2024 13:00 #302080
Unfortunately laptops are usually not good real time hosts for LinuxCNC
because they often have power management features that cannot be disabled
That said, some are OK
The following user(s) said Thank You: Anton
- Anton
02 Jun 2024 03:51 #302132
by Anton
Good morning.
I have gone through points 1 to 5.
to 1) see histogram in the appendix
2) I cannot change any of the properties mentioned in the bios.
3) There is also no way to deactivate hyperthreading.
to 4) I have read hm2_eth. In the file /etc/network/interfaces there was only the loopback interface. I added eth0 there (see picture in the attachment). The entry is probably wrong because I don't have eth0. My interface is called enp5s0 !?
to 5)
a) ping -i .2 -c 4 10.10.10.10
-> min: 0.093 avg: 0.135 max: 0.240
b) sudo chrt 99 ping -i .001 -q 10.10.10.10
(see picture in the appendix)
Best regards
to 5)
Best regards
- Thank you received: 7506
02 Jun 2024 07:16 - 02 Jun 2024 08:44 #302142
Replied by tommylight on topic error finishing read!
Deleted as i missed the screenshot showing the correct address.
Last edit: 02 Jun 2024 08:44 by tommylight. Reason: See above.
- Anton
02 Jun 2024 08:18 - 02 Jun 2024 08:46 #302149
by Anton
No, I am already pinging from 192.168.1.120 to 192.168.1.121. In the text, I accidentally copied the IP from the PCW instructions. The ping works, it is probably a latency problem.
Last edit: 02 Jun 2024 08:46 by Anton.
02 Jun 2024 08:43 #302151
Sorry, missed that, no idea how but probably lack of sleep.
The 9.4nS time is way to much, there is another topic with similar results, so can you try this:
-click on "routen"
-check the "use this connection only for resources on this network"
-click OK
-click "save"
-close
-click on the network manager icon and click on "wired connection 1"
-pins as advised by PCW
-click on "routen"
-click OK
-click "save"
-close
- Anton
02 Jun 2024 08:51 #302153
by Anton
Thank you very much, I will give it a try later.
Unfortunately, I can't evaluate the result of the ping and the histogram.
Which value is too large and how large should it be? best regards
02 Jun 2024 09:01 #302155
Your fist screenshot above (with the correct address
) shows on the last line the min/avg/max/mdev values, the max value is above 9.4.
Please do this ping test again after all the above clicks and report back, it would be helpful if we can pinpoint what causes such high network latency.
Thank you.
Thank you.
Time to create page: 0.163 seconds
