Mesa 7i95T: Smartserial Port 2 for Mesa Modbus RS485
- scda
- Thank you received: 3
02 Jun 2024 15:37 - 02 Jun 2024 15:39 #302166
by scda
Mesa 7i95T: Smartserial Port 2 for Mesa Modbus RS485 was created by scda
Hello everybody
For my next project (retrofit of a weiler 160 cnc lathe) I plan to use a 7i95T because it has plenty of IO and also enough Encoder inputs (I need at least 3, maybe 4 later, for the tailstock). I have a 5.5kW Huanyang VFD which i would like to integrate via Modbus to simplify wiring and access more drive parameters directly (spindle load or output power).
As far as I can see there is no precompiled firmware available for the 7i95T using Smartserial Port 2 (or Port 1 is also ok) as RS485?
In Mesa Modbus I will need to create my own xyz.comp file and compile it. I suppose this has not yet been tried?
Is there a table with the Modbus registers availble for the Huanyang HY drives? In my manual there is a description of the protocol but no parameter list for the MODBUS registers.... Maybe someone can help me find such a table.
Cheers,
Dave
Cheers,
Dave
Last edit: 02 Jun 2024 15:39 by scda.
- Thank you received: 5334
02 Jun 2024 15:58 - 02 Jun 2024 21:59 #302168
Replied by PCW on topic Mesa 7i95T: Smartserial Port 2 for Mesa Modbus RS485
I can make this firmware when I get a chance (Just made it for 7i95)
OK already exists:
7i95t_1pktv2d.bin
OK already exists:
7i95t_1pktv2d.bin
Last edit: 02 Jun 2024 21:59 by PCW.
The following user(s) said Thank You: scda
- scda
11 Jun 2024 19:12 #302845
by scda
Replied by scda on topic Mesa 7i95T: Smartserial Port 2 for Mesa Modbus RS485
Oh perfect. Did not see this.
Time to create page: 0.196 seconds
