Will a 7i97T work with in a 3axis teknic setup
07 Jun 2024 23:59 #302578 by EverydayDiesel
Will a 7i97T work with in a 3axis teknic setup was created by EverydayDiesel
Hello,  I am curious if a 7i97T will work in a mill configuration with 3 axis using teknic servos.  Eventually I want to be able to control the spindle speed from linux cnc but that will come later.  Will a 7i97T work on my setup?
Thanks in advance
08 Jun 2024 00:03 #302579 by PCW
What kind of drives does the machine have?
The following user(s) said Thank You: EverydayDiesel
08 Jun 2024 00:07 #302580 by EverydayDiesel
Replied by EverydayDiesel on topic Will a 7i97T work with in a 3axis teknic setup
they are teknic clearpath servos.
X and Y have SDSK-3421S-RLN
teknic.com/model-info/CPM-SDSK-3421S-RLN/
and the Z has a SDSK-3432S-RLN
teknic.com/model-info/CPM-SDSK-3432S-RLN/
08 Jun 2024 00:15 #302582 by PCW
Those are step/dir drives so a 7I97T is not appropriate but a
7I96S would work.
08 Jun 2024 00:17 - 08 Jun 2024 00:31 #302583 by EverydayDiesel
Thank you so much. I am purchasing now. Do I need anything else from mesa?
I also have a brake (for the Z) that takes 24v and an omron 24v power supply.
teknic.com/products/spring-applied-power...rakes/NEMA-34-brake/
I have 3 of these cables (also have 3 ipc5 power supplies and the power cord for them)
teknic.com/cpm-cable-ctrl-mu120/
Last edit: 08 Jun 2024 00:31 by EverydayDiesel.
08 Jun 2024 00:26 #302586 by PCW
Not from Mesa but you will need a 5V power supply and an Ethernet cable
Moderators: PCW, jmelson
Time to create page: 0.109 seconds
