7i77 mode 3
09 Jun 2024 17:57 #302691 by Hawk83
7i77 mode 3 was created by Hawk83
Hi folks.
When operating the 7i77 board in mode 3, can I still use inputs 0-3 as normal digital inputs with field voltage (24V) compatibility?
I want to be able to connect an MPG to inputs 16 and 17, but I have no need for the analog inputs (inputs 0-3) that are enabled in mode 3.
09 Jun 2024 18:04 #302693 by PCW
Replied by PCW on topic 7i77 mode 3
Yes, the analog and MPG modes do not interfere with use of the standard
digital inputs and their normal input thresholds. The digital,  analog and
MPG modes  just process the input analog data differently.
The following user(s) said Thank You: Hawk83
09 Jun 2024 18:28 #302696 by Hawk83
Replied by Hawk83 on topic 7i77 mode 3
Thank you so much for your fast reply PCW.
Does that mean that I can run the board in mode 3 and use inputs 16 and 17 as MPG-inputs and use inputs 18 and 19 as normal digital inputs with full field voltage (24V) compatibility?
09 Jun 2024 18:42 #302698 by PCW
Yes
Moderators: PCW, jmelson
Time to create page: 0.098 seconds
